Old 08-27-2014, 07:21 PM   #1
Dcm
Engine origin
I have a 1970 swb half ton fleet side with cool spring rear suspension. The info from decoding the vin says the truck came from St. Louis and had a V8 and a 4 speed manual tranny. The engine "looks" original (ram horn exhaust manifold, chevy intake and heads, quadrajet carb). But when I ran the numbers on the engine it came up with an age range bracket of 74-78. The numbers on the intake point to a car from mid 70's with a four barrel. The vin on engine doesn't match vin on truck. Is this a fairly common occurance and are there any "gotcha's" to watch out for?
Dcm is offline   Reply With Quote
Old 08-27-2014, 07:25 PM   #2
wreckedchevy
wreckedchevy's Avatar
Re: Engine origin
I'm guessing they probably swapped motors at some point I know in the 21 years I've owned mine I've rebuilt the original 250-6 then installed: 350, 307, and currently running a 305 out of a mid 80's c10
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 08-27-2014, 07:44 PM   #3
zeldman
zeldman's Avatar
Re: Engine origin
I would say that in the last 44 years someone has swapped out the 307 for a 350, and put a 4 BBL carb on it. Not unusual at all.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 08-27-2014, 08:05 PM   #4
davepl
davepl's Avatar
Re: Engine origin
If there's a VIN on your engine, it's not for one of these trucks. Sadly we got casting code (the 3-letter code) and not much more. There is no partial VIN or even sequence number on truck engines.
So just the fact it has a vin excludes it, and the dates back that up.
If not being the original engine is OK with you, just make sure it's not a 305 instead of a 350. I seem to recall it not being that easy to distinguish for some reason.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-27-2014, 08:47 PM   #5
Dcm
Re: Engine origin
As long as the engine is a usable 350 block, I'm happy. And according to the casting info, it's a 350. 3970014CMA
Old 08-27-2014, 09:09 PM   #6
Hutch
Hutch's Avatar
Re: Engine origin
Decodes as
CMA 1974 350 Turbo Hydro trans. - - 2 Barrel carb Body A B F X
information from http://www.nastyz28.com/gm-chevy-cod...s-suffix-2.php
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
