Can I use a 69 c20 single rear wheel front disc set up on a 68 dually?
I have a 68 dually car hauler. I've read a bunch of disc brake threads here - so pls excuse any ignorance. I can get a 69 c20 8 lug disc set up, but it appears from reading here that the hub will be different than I need for the dually type front wheels.
Two questions: Am I correct? If so, is there a straightforward solution? Thanks much |
Re: Can I use a 69 c20 single rear wheel front disc set up on a 68 dually?
To run dually wheels on the front you need dually hubs. I would say you need either 67-72 or 73-87 (will need other componets). I would search for dually disc brake conversion or build threads. Maybe somebody else will chime in.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
![]() Join Date: Mar 2003
Your 69 is going to drum also, unless it was converted sometime in the past
![]() Join Date: Feb 2007
I have a complete front c-member off of a mid 70's c-30. Do u have anything u want to trade? Thanks Frank
So the answer is no, you can't use the 69 c20 brakes on a c30 dually??
