09-01-2014, 09:05 PM | #1 |
air injection manifold plugs
ok so my 350 has the air injection set up and broke one of the tubes that goes to the manifold so i have a leak got the nut out of both sides tonight was just wondering if anyone knew the thread or where to get plugs so i can pass a cop with out being to loud lol, thanks mike
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
09-01-2014, 09:15 PM | #2 |
Just here to tinker
Re: air injection manifold plugs
I've had luck with Cummins engine oil drain plugs working.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
03-28-2015, 01:10 PM | #3 |
07-13-2021, 12:40 PM | #4 |
Bump. Anyone have an answer to this?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-14-2021, 07:39 PM | #5 |
Just here to tinker
Been a long time since I worked on this stuff, but try buying one of these and see if it works.
M22x1.5 https://www.napaonline.com/en/p/NDP7...&gclsrc=aw.ds&
07-15-2021, 09:03 AM | #6 | |
09-01-2014, 09:39 PM | #7 | |
I only did it on my Ford, but it should be the same. The threads should be NPT (national pipe thread) so take the piece you removed to Lowes or Home Depot to match it up. Some auto parts stores might have NPT plugs too.
09-02-2014, 02:34 AM | #8 |
I use 1/4 in. npt plugs.
09-02-2014, 12:50 PM | #9 |
it dont seem to be npt seem metric??? its a crate motor form mexico if that helps any and this is 3/4 od like a half inch pipe
09-02-2014, 08:00 PM | #10 |
Just here to tinker
19mm and yes the threads are straight. No idea what pitch i.e.: 1.5, 1.25, etc. This is what a cummins drain plug is.
09-02-2014, 02:56 PM | #11 |
I measured mine a few years ago. They were 19mm with a very fine thread and straight [not tapered]. Also the threaded hole wasnt that deep, so tapping them to pipe thread would be iffy. I would try a drain plug [Corts60] first. You need a friendly parts guy to try out the many sizes.
P.S. At the bottom of the threaded hole, the size reduces down to about 5/16 or so. You could try tapping that to a pipe plug, but I dont think there is much material to work with. |
03-27-2015, 07:04 PM | #12 | |
03-27-2015, 08:14 PM | #13 |
well see its like this, i gave the old nut that goes around the tubing to my gf and she found a plumbing bushing that fits. it is the most odd ball thing ever. it is comp by pipe adt and it went right in. think it is 3/4 can take a pic if needed but its not pretty. but i dont care it works
03-27-2015, 10:16 PM | #14 | |
03-27-2015, 10:36 PM | #15 |
Most GM AIR injection tubes are fitted to the manifolds with flare nuts which are straight threads not NPT. I always use Allen head set screws. The size I have used is 1/2 X 20 the taper of the set screw tip is close enough to the 45deg flare which lets the set screw seal at the flare not the threads. I also use anti-seize on the threads for removal at a later time.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
03-27-2015, 11:44 PM | #16 |
When I had to replace the air injection tubes on my 350, we drilled the old flare nuts out and cleaned the threads up with a pipe tap. We discovered that they were a standard 1/4 inch NPS thread and dug up a straight plug tap to do the job.
A 1/2 by 20 plug would work worse than a 1/2 by 13 plug as the normal pitch of a 1/4. inch pipe thread is 14 TPI
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive! 1992 K1500 ECSB- 190K miles- I guess I'm just a truck guy now! |
03-28-2015, 12:08 AM | #17 | |
03-28-2015, 01:02 PM | #18 | |
It looks like fine thread . An earlier post, Someone posted they used 19mm oil drain plug from Cummins diesel . Does anyone know year make model plug is from? Or if any of you can point out the plug I need would be very helpful . Thank you! |
03-28-2015, 07:31 AM | #19 |
here is one thing i want to ask on this. are you guys using the 1/2 on the single line air or is it on the ones with 3 or 4 lines to the manifold?? mine is single
03-28-2015, 11:29 AM | #20 |
Sorry I was talking about the standard four tube AIR rail to exhaust manifold.
