09-03-2014, 12:38 PM | #1 |
something is loose when hard accelerating
I've had this issue for a while now when I floor it from a dead stop....something feels loose in the drivetrain (maybe)
My suspicions are motor mounts, trans mounts, u-joints or carrier bearing....LOL It's hard to describe, but something def isn't right when taking off fast....I think its from the flexing of the engine or driveshaft Anyone ever experience this or have any ideas??
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
09-03-2014, 03:04 PM | #2 | |
Re: something is loose when hard accelerating
Or, perhaps you should check your passenger side motor mount. |
09-03-2014, 03:30 PM | #3 |
LOL @ Fitz
How do you check motor mounts? Is the passenger side more prone to going bad more so than the drivers side? Thanks,
09-03-2014, 04:04 PM | #4 |
your engine naturally wants to pull, so one easy way (but not foolproof) is to obviously do a visual inspection, but you can also pull your throttle from the carb while watching the engine. I'm not saying it's the best way, but I've been able to find a broken mount like that, albeit, a different vehicle. Best of luck!
09-03-2014, 04:57 PM | #5 | |
My tires are the clutch that protects the rest of the drivetrain in my truck on hard starts, hence the flippant answer. |
09-03-2014, 05:07 PM | #6 |
hahaha Thanks Fitz!
When jacking up the engine, how do you do one side at a time? I thought you put a block of wood between the jack and pan and lift up....is this correct?
09-03-2014, 07:06 PM | #7 |
Correct! Your method is better than mine. You'll have to release the bolts on both mounts before lifting and all you really need is to get the weight of the engine off the mount, not raise the motor much at all. 1/8th inch should do it. I usually use a pry bar but that can get a bit clumsy if the truck is not on a lift.
09-03-2014, 05:16 PM | #8 | ||
"I ain't nobody, dork."
Put a blcok of wood between the jack and the pan. If you have a busted mount. That side will raise.
Gary
09-04-2014, 12:37 PM | #9 |
I've had two carrier bearings on two different trucks go bad, and that definitely could do what your describing. Have you visually checked it?
I had one where the bearing itself was wobbly, which sounds like maybe what's happening to you. The other one broke the actual mounting plate off, that one was not a subtle noise and/or hard to diagnose. KER-PLUNK-KER-PLUNK-KER-PLUNK-KER-PLUNK!!!
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
