09-03-2014, 06:36 PM | #1 |
Need a pic of parking brake cable mount
Does the parking brake cable outer shielding mount to the parking brake assembly at all? In my case I have it just coming through the firewall grommet and connected the inner cable to the clevis/pin part.
This in turn has bent the outer cable where it mounts to the inner fender to almost a 90 degree angle, so something's not right. I'm thinking that I'm missing a clamp or something, but rather than invent something I'm hoping someone can snap a photo under the dash. Any foot-brake truck should do! Thanks, Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
09-03-2014, 06:54 PM | #2 |
Re: Need a pic of parking brake cable mount
Does this help? Want an under hood shot also?
09-03-2014, 06:57 PM | #3 |
Yep. And now I know what the piece is for too, it's in my "not sure" pile. :-) Thanks very much!
09-03-2014, 09:20 PM | #4 |
Helps me too thanks. How about pics of it in the engine Bay Area?
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
09-03-2014, 09:55 PM | #5 |
Top- engine bay.
Bottom- where it attaches to frame. |
09-03-2014, 09:56 PM | #6 |
Thank you.
09-03-2014, 09:56 PM | #7 |
On my truck when I took it apart that rubber section was crushed between the cab and the frame. Assembly error at the factory, I assume. I did not replicate it when I put it back together, I did like the photos above.
09-03-2014, 09:59 PM | #8 |
For what it's worth... cables are the originals and routing is as original.
09-03-2014, 10:59 PM | #9 |
Thanks very much folks. My park brake was not (as you can imagine) inspiring much confidence, as it was missing this crucial mounting point. I've now installed it and the pedal is great - only can travel a little more than half way, no brake drag, the pedal pops strongly back on release, and it locks the wheels hard when applied.
Couldn't ask for more! Well, except maybe for having done it right in the first place...
09-03-2014, 11:03 PM | #10 | |
Jim |
11-27-2015, 09:37 PM | #11 |
LET'S GO...MOUNTAINEERS
Anyone know where I can pick up the retainer in the first picture? I seem to have lost mine over time and now I am in need of a parking brake for state inspection. Thanks.
72 SWB/Step |
06-02-2016, 10:46 PM | #12 |
bump. Anyone have any ideas on where to get one of these? Or exactly what it's called so I can search on my own?
Thanks |
06-03-2016, 06:58 AM | #13 |
Old member
Junkyard would be my first place to check.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
