09-10-2014, 07:53 PM | #1 |
Need help with drive line
I took a 1970 gmc 2 wheel drive and short boxed it.My donor truck was a 1976 c 10 front and rearend.I used the 3/4 ton drive line,so what universal will fit it? 3/4 ton one end 1/2 the other end any help thanks.
09-10-2014, 08:54 PM | #2 |
Re: Need help with drive line
It depends on your driveshaft.
I assume you have a small u-joint driveshaft and a large u-joint rear-end? If so, you need an "adaptor" u-joint for the pinion end, a 1310 to 1350 style. http://www.ringpinion.com/technicalh...plications.inc You COULD get a driveshaft yoke for big u-joints and use big u-joints on both ends. Probably a good idea if you end up using a custom driveshaft. http://www.dennysdriveshaft.com/c75_general_motors.html |
09-10-2014, 09:54 PM | #3 |
I used the old end on drive shaft so the drive shaft needs a big one and the rearend needs a small one
09-10-2014, 10:15 PM | #4 | |
https://www.google.com/#q=1310+to+1350+u+joint&tbm=shop Last edited by mechanicalman; 09-10-2014 at 10:21 PM. Reason: add-on |
09-11-2014, 07:58 PM | #5 |
Ok thanks for your help.
09-12-2014, 08:27 PM | #6 |
I got the u joint, going to put it in Saturday.
