09-14-2014, 11:17 AM | #1 |
Carpet or upholstery to replace area where gas tank once was
Can any of you guys direct me to a vendor that sells molded carpet in the area where the gas tank once was I moved my tank to the back.
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: |
09-14-2014, 11:33 AM | #2 |
Re: Carpet or upholstery to replace area where gas tank once was
the floor or the back of the cab?
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
09-14-2014, 12:28 PM | #3 |
Google flexformcarpet it is a non backed carpet made to flex and form to uneven shapes it comes in 40 and 80 inches wide and a number of different colors it should work for what your describing .Varies in price from $11.80 to $28.00 depending on color and width ,You can install it with spray can contact cement ...
09-14-2014, 12:34 PM | #4 | |
09-14-2014, 02:37 PM | #5 |
I'm gonna either get a thin piece of wood panel , spray on glue, and put on sub woofer box covering and screw in place or put the covering on the sound deadener covering and then directly on the sheet metal with spray on glue. Hope this helps. Show pix when ya get'er done.
09-14-2014, 12:33 PM | #6 |
The back of the cab, where the gas tank was originally.
09-14-2014, 02:48 PM | #7 |
Laid Back
We sell a back wall curtain for when the tank is removed.. Made by trim parts carpet.
Kyle
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
09-14-2014, 03:01 PM | #8 |
Do you have a picture Kyle?
09-14-2014, 05:55 PM | #9 |
Old member
I got to ask. If you removed the tank are you going to put a sound system in the truck? If so build the box to cover the back wall. I covered mine with sound deadner then built the sub box. I bought the carpet stuff at O Reilly's.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
06-14-2017, 09:49 AM | #10 |
Kyle, are you still around, you haven't posted in awhile. Do you have details of this product?
72 White Cheyenne, The Ghost |
