Old 09-14-2014, 02:28 PM   #1
68Timber
I know the pieces fit
68Timber's Avatar
'74 Honda Z50
I'll state up front I have zero need for this and it was a bad idea to bring it home with two project trucks already in the drive, but hey, it happened. I found this on craigslist and happened to have empty pockets that day, but I texted it to a friend and he ended up buying it. Several months down the road he'd bought a new house and hadn't started on the bike when he offered it to me for what he had in it.
It didn't run, so it was cheap. The PO had installed shocks off a 70 to get the seat height up but the orginals came with it. Also, the original gas tank was rusted through on one side but my friend had bought a new aftermarket replacement that came with it. So it's all there except for the original tailpipe. It also came with new tires and tubes. Here's what came home.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-14-2014, 02:36 PM   #2
68Timber
68Timber's Avatar
Re: '74 Honda Z50
The plan was to clean the carb and get it running first then make it pretty. But the original plastic intake spacer was cracked around the bolt holes when I started. So I cleaned the carb, started cleaning on the original shocks, and then I got impatient. So I went ahead and started taking it apart.
John
74 Honda Z50 build
Old 09-14-2014, 02:49 PM   #3
68Timber
68Timber's Avatar
Re: '74 Honda Z50
I left the forks and swing arm on the frame and broke out the pressure washer. Underneath it had been blue once and green before that. It will be blue again, that was the color tank my friend bought. I also got the tires cut off and the wheel halves separated and run through the blast cabinet and got everything in primer.
John
74 Honda Z50 build
Old 09-14-2014, 02:58 PM   #4
68Timber
68Timber's Avatar
Re: '74 Honda Z50
Here's where I ran into a snag. The replacement tank was painted the correct '74 Honda blue. All the paint I'm using is rattle can, but I do want it to look right, and the cheapest I could find the correct paint in rattle can was $90-something a can online. I was in Car Quest and saw GM Bahama Blue for $7 a can and decided to run with it. But the tank wasn't going to match, unless...
John
74 Honda Z50 build
Old 09-14-2014, 03:04 PM   #5
68Timber
68Timber's Avatar
Re: '74 Honda Z50
Yes, I sanded the cracks out of the primer. That was Rustoleum Filler Primer, and it cracks while drying if you lay it on too thick. So I used a regular primer and sanded it smooth with 400 grit and sprayed it with the Bahama Blue. It came out really nice. I have cleared it since this picture and don't have any regrets sanding down a painted and ready to go tank - it really does look nice. I'll get a better pic later.
John
74 Honda Z50 build
Old 09-14-2014, 03:10 PM   #6
68Timber
68Timber's Avatar
Re: '74 Honda Z50
So, from what I've seen online, the frame is supposed the be black and the forks match the tank and side cover. So, more sanding and painting... The wheels are done with the new tubes/tires installed. The wheels were painted with GM rally silver since I had a few cans.
John
74 Honda Z50 build
Old 09-15-2014, 10:05 AM   #7
tommys72
tommys72's Avatar
Re: '74 Honda Z50
Pretty neat little project
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 09-15-2014, 10:26 AM   #8
jchav62
1962 C-10
jchav62's Avatar
Re: '74 Honda Z50
Too cool!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-16-2014, 09:35 AM   #9
chevyrestoguy
chevyrestoguy's Avatar
Re: '74 Honda Z50
I've still got my 1969 Z50 K1, which was my first motorcycle. It needs to be completely restored, but it'll happen as soon as I can get a couple of other projects done first. My bike is the factory candy red with the candy red/silver tank.
I also have a "barn find" 1968 Honda CT90 that runs like a top. I love vintage Japanese bikes because they are a real flashback to my youth.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-16-2014, 02:05 PM   #10
68Timber
68Timber's Avatar
Re: '74 Honda Z50
Originally Posted by jchav62 View Post
Too cool!
Thanks guys!
I know what you mean. There was a old green and original XL75 at the Moultrie swap meet last year I wanted to bring home. My bud thought I was nuts. Post a pic of your Z50 if you have one, and very cool that you've hung on to it!
John
74 Honda Z50 build
Old 09-16-2014, 08:56 PM   #11
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Re: '74 Honda Z50
I always liked the blue 1st gen Z50s... good lookin little bikes...
CLick the link in my sig, we retro modded my old 79 Z50. Little thing sure surprises people when they see my big a$$ comin... LOL
125CC CDI ignition, Extended forks and swingarm, 10" wheels cafe'd bars and a QA 50 seat,
screamin_c10 is offline   Reply With Quote
Old 09-17-2014, 03:49 PM   #12
68Timber
68Timber's Avatar
Re: '74 Honda Z50
That's cool! I'd like to do a custom (but cheap) mini some day but it would definitely have to be on down the road. What kind of exhaust is that?
John
74 Honda Z50 build
Old 09-17-2014, 04:04 PM   #13
mark 66
Re: '74 Honda Z50
cool little project. be careful those small bikes can be addicting.got a llttle ct 70 myself.keep it to terrorize the neighborhood
mark 66 is offline   Reply With Quote
Old 10-01-2014, 01:24 PM   #14
68Timber
68Timber's Avatar
Re: '74 Honda Z50
Thanks, and I've already been looking for another one.
I was waiting for the paint to fully harden before putting it back together, but the front forks were nagging at me. The upper fork bridge has two holes in it for tabs on the upper spring holders, so they won't spin in the forks I guess. Except the tabs on these upper spring holders had cracked off and left the party at some point, and it got to bugging me. And I didn't know how to take the forks apart, so I had to order a Clymer manual. So I'll get to clean these up and reassemble them with the new upper spring holders when they get here. Except now I'm thinking I can paint the and frame better if I don't have to mask anything? Scope creep, I guess, but it'll be nicer for the effort. I hope!
John
74 Honda Z50 build
Old 10-02-2014, 07:24 PM   #15
Boog
laying low
Boog's Avatar
Re: '74 Honda Z50
That's a good looking blue John. Chrome fenders? A new 40 year old mini is something you don't see everyday. What are you going to do with it when finished?
We used to use those and mini bikes as pit bikes at the drag races.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-18-2014, 11:37 AM   #16
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: '74 Honda Z50
Nice little bike.
My wife's Uncle has a few of the Honda Trail 70's. I might have to work on him to sell me one at a fair price for someting fun to tool around on..
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-18-2014, 01:42 PM   #17
68Timber
68Timber's Avatar
Re: '74 Honda Z50
Thanks man. I ordered a clutch nut removal socket from the local Honda shop so I can check and make sure the clutch discs are in spec before I button it back up mount it in the frame again. If I could get just one weekend that I didn't have to go out of town for something I might could finish this thing.
John
74 Honda Z50 build
Old 12-18-2014, 08:21 PM   #18
Boog
laying low
Boog's Avatar
Re: '74 Honda Z50
The end is in sight now John. All you lack is finishin up. It sure looks like new.
Hmm. I wonder how one of those built into a mini chopper would work or a trike?
Boog
primer is finer
Old 12-19-2014, 08:25 AM   #19
68Timber
68Timber's Avatar
Re: '74 Honda Z50
Jim, actually I was thinking of a 80's or 90's model with motard tires, a pipe, and mini-apes. I'll have to find a good runner at a cheap price though.
John
74 Honda Z50 build
Old 06-14-2015, 11:21 PM   #20
68Timber
68Timber's Avatar
Re: '74 Honda Z50
I let this sit a while but have been messing with it again lately. It might even run again. I cleaned and degreased the engine. The side covers are off, I used PB blaster-soaked-red scotchbrite pads on the engine to give it a reasonably even finish.
John
74 Honda Z50 build
Old 06-22-2015, 01:56 PM   #21
made2drag
made2drag's Avatar
Re: '74 Honda Z50
Dang, it's coming right along. Nice fit with the tab....dead on...I wish i were closer, I could weld that up in 2 mins.
made2drag is offline   Reply With Quote
Old 02-24-2016, 09:41 PM   #22
dbstepside
dbstepside's Avatar
Re: '74 Honda Z50
So this is your signature so I had to look. Did you ever get it done? And btw I love the Bahama Blue.
dbstepside is offline   Reply With Quote
Old 02-24-2016, 09:57 PM   #23
68Timber
68Timber's Avatar
Re: '74 Honda Z50
No, I haven't finished it. And it doesn't look very good right now with eight months of shop dust on it. When this happened I hadn't started welding yet. I've since started welding some and I think I can weld that stop on. I'll get working on it shortly, I'm tired of stepping over it. LOL
John
74 Honda Z50 build
Old 02-25-2016, 11:24 AM   #24
aggie91
aggie91's Avatar
Re: '74 Honda Z50
Did you see the one that was done at Gas Monkey for the show? It "sold" at an auction for $5200...after it was turned in to a trike...
Karl
The LST Challenge:
Old 02-25-2016, 12:50 PM   #25
68Timber
68Timber's Avatar
Re: '74 Honda Z50
That was cool. He put too much motor on it, but still. The green and the wheels, looked great.
John
74 Honda Z50 build
