Identify camper special?
Is there anyway to identify a camper special if there is no badging? My 72 C20 has HD suspension, Dana 60 rear leave springs and a what appears to be a camper electrical connection in the left rear of the bed.
![]() Join Date: Apr 2012
Re: Identify camper special?
Hello,
I have a 71 Custom Camper that I plan on parting out. The spid shows it as Z81 special camper. Hope this helps, I am sure others will chime in on the subject. Paul |
Thank you. It would seem then that although it has similar options it was not a camper special. I am at a loss to explain what appears to be a factory installation electrical port in the bed. Does your truck have a 4 pin electrical port/plug/recepticle in the left rear of the bed?
Could be a dealer installed item?
And a "Camper Special" is a Ford. A "Special Camper" is a Chevy/GMC
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD. 1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc |
I beg forgiveness on the special thing. My uncle had one of the fords and it was just on my brain at the time.
Given spid's shown here I am pretty sure the truck was just a deluxe and the power recepticle was probably dealer or owner installed. Thanx to all who responded. |
![]() Join Date: Jun 2014
Here is my 72 Custom Camper C20
Hope this helps!
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
![]() ![]() Join Date: Sep 2008
My 71 GMC says nothing about Special Camper, but it has UY1 Camper Wiring. The harness appeared to come up between the cab and bed originally and was attached to the bed with clips.
![]() Join Date: May 2010
The Custom Camper nameplate option was available at no cost when a truck was equipped with certain options. Many trucks, such as my 69, qualified but did not carry the nameplate since it wasn't requested. The required 1972 options were:
- Front stabilizer bar. - 2750# rear coil springs or 500# auxiliary springs. Available leaf spring rear suspension also rated at 2750# also qualified. - HD rear shocks. - Minimum of 7.50-16/D tube type tires or 8.75-16.5/D tubeless tires or larger. Tire size normally did not appear on the SPID. The camper wiring option was not required. The harness was run from the frame through a clip screwed to the back of the cab just above floor level, bundled and placed in the left front stake pocket. It did not have a connector on the end. |
