Old 09-20-2014, 12:29 AM   #1
Jbm1956
6 lug to 5 lug
Im building my 56 Chevy pickup and I have a 12 bolt rearend with 5 lug and have the lowered axle with 6 lug still in the front. Can I change the front over to 5 lug without going to disc brakes or is discs my only options?? I think if I go with the discs up front ill have to buy the disc brake kit and then buy the power booster and master cylinder right? If thats the case I would rather spend the money somewhere else for now. Thanks guys
Jbm1956 is offline   Reply With Quote
Old 09-20-2014, 01:49 AM   #2
yossarian19
Re: 6 lug to 5 lug
You may have to look around a little more but you can find five-lug disc kits that don't come with the master / booster combo. Try Speedway Motors, I think they had something for $250.
6x5 1/2 is a *lot* cooler than 5x 4 3/4. 5x5 ain't bad though.
(I really don't know why I have actual feelings about bolt patterns)
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 09-20-2014, 01:59 AM   #3
Jbm1956
Re: 6 lug to 5 lug
If I do the disc brake kit dont I have to run a new booster and master
Old 09-20-2014, 08:27 AM   #4
DaveCt
DaveCt's Avatar
Re: 6 lug to 5 lug
I dont think so, but you'll need a proportioning valve though.
DaveCt is offline   Reply With Quote
Old 09-20-2014, 11:21 AM   #5
yossarian19
Re: 6 lug to 5 lug
You don't have to run a booster. I don't know if you *have* to run a new master, but I know that you darned well *should* whether you run drums or discs.
Single pot master cylinders with single circuit distribution are one of those things that really needed upgrade. A lot of the rest that we've done with cars in the last 50-odd years, I can take or leave. Brake hydraulic re-design, we've done good.
"Over my head"
Old 09-20-2014, 10:09 AM   #6
Rude Dude
Rude Dude's Avatar
Re: 6 lug to 5 lug
If you want five lug drum in front 49-54 chevy car hubs/drums fit on 55-59 trucks.
Rude Dude is offline   Reply With Quote
Old 09-20-2014, 12:06 PM   #7
mgchevyparts
mgchevyparts's Avatar
Re: 6 lug to 5 lug
Absolutely correct
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 09-20-2014, 02:41 PM   #8
butchp
Re: 6 lug to 5 lug
Originally Posted by mgchevyparts View Post
Absolutely correct
And you get the better bearing, I have a set.
butchp is offline   Reply With Quote
Old 09-20-2014, 03:11 PM   #9
mgchevyparts
Re: 6 lug to 5 lug
47-54 cars and the47-59 1/2 ton trucks use the same bearings, B01 and B52 ball bearings. The better bearing is the tapered equivalents that are available to change to a roller bearing.
The 5 on 4.75" car hubs do interchange with the trucks.
Old 09-20-2014, 11:35 AM   #10
nvrdone
Re: 6 lug to 5 lug
Ive got 49 - 54 drums on the front on my '49 with a dropped straight axle. I also changed over to roller bearings instead of ball bearings. I have part #'s if you need them.
I also added a CCP m/c & booster kit under the floor. Stops much better than stock.
Now when I have more $$ I may change to front discs
nvrdone is offline   Reply With Quote
Old 09-20-2014, 12:18 PM   #11
nvrdone
Re: 6 lug to 5 lug
I agree with changing to a new m/c. I had the old single circuit brakes and broke a brake line.
My seat still has the butt pucker marks and brown stains.
Old 09-20-2014, 05:40 PM   #12
Russell Ashley
Russell Ashley's Avatar
Re: 6 lug to 5 lug
Get the disk brake kit, you'll be glad you did. That was one of the best upgrades I made to my truck. I added the power booster too but some folks on this forum have put disks without a booster. I wouldn't spend money on swapping to five lug drums only to swap to disks later.
Russell Ashley is offline   Reply With Quote
Old 09-21-2014, 08:20 AM   #13
1project2many
Re: 6 lug to 5 lug
Are you talking about a truck 12 bolt or car axle? The 65+ fullsize Chevy (Impala, Biscayne) use the same 5 X 5 bolt pattern as 2wd trucks while the older fillsize cars (but not wagons) use the same smaller 5 X 4.75 pattern as Chevelles, Novas, etc. "Back in the day" folks would swap to the front brakes from the late '60s Impala to get the big five pattern and 11 X 2.75" brakes vs 11 X 2" that are stock.
1project2many is offline   Reply With Quote
