09-20-2014, 09:37 AM | #1 |
Throttle cable
I hate being a pain with these questions, but this swap from a 6 to sb v8 is one problem after the next. I bought a new throttle cable because the 6 cyl cable was to long. The new one is shorter, but still to long. I also am having trouble finding a throttle cable bracket.
Could someone possibly post a photo or two of their K10 engine area showing correct bracket and cable connections? I have my engine running great, and I can move it back and forth in my driveway, but can't go any further until I get this throttle problem taken care of
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
09-21-2014, 03:30 AM | #2 |
Re: Throttle cable
Are you looking for a choke cable, or an accelerator cable?
I bought a repop accelerator cable, made it into a sweeping "S" bend, lubed it up really well and hooked it up. Easy as pie.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
09-21-2014, 09:21 AM | #3 |
Re: Throttle cable
Sorry, an accelerator cable. I bought the one at LMC that says it's for a 350 4wd. Part# 32-4525. Maybe after I get a mounting bracket I might be able to get this cable working. LMC has a universal 'throttle cable bracket' 38-4708, but I think I'll explore other options before dropping $40 on somthing I'm not sure woukd even work. Still hoping for a photo or two of a correct installation :-)
09-22-2014, 12:11 PM | #4 |
Re: Throttle cable
Get on craigslist and find a parts truck. I find them all the time. In fact I'm going to get some parts off of a 72 k5 today.
1972 k/10 4x4 swb 2011 camaro SS/RS M6 |
09-22-2014, 12:43 PM | #5 |
Re: Throttle cable
Put a 700R4 trany in and move your engine forward 2" and your problem is solved... "LOL" That's the set-up I have, but haven't installed the cable yet, just put the peddle assembly in the other day. I do have both the long & short cables, hopefully one will work.
As Jason mentioned above, I believe the original set-up had an S curve in the cable. As for the bracket I went with a Holley bracket ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
09-22-2014, 12:50 PM | #6 |
Re: Throttle cable
Shortening the cable isn't that hard.
03-05-2015, 12:22 PM | #7 |
Re: Throttle cable
Can you give some details on how you did it?
1971 GMC 4x4 4 speed Project |
03-07-2015, 04:13 PM | #8 |
Re: Throttle cable
This is a Lokar cable and bracket. They make pretty much whatever you need but they are REAL proud of their stuff. I guess it depends on how much $$$ you want to spend.
1968 K10/30 Frame Off Project "Overkill" My 5 year, $30,000.00 toy |
03-08-2015, 12:46 AM | #9 |
Re: Throttle cable
Lokar has a universal cable kit that is under $50 if I remember right. Just like making a bike brake cable.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-08-2015, 12:49 AM | #10 |
Re: Throttle cable
03-08-2015, 04:39 AM | #11 |
Re: Throttle cable
I have a 66 k10 that I modded to use a cable for the throttle.
I got the parts at the local junkyard, and grabbed 2 different length cables, figuring one of them would work. The shorter cable was difficult, and almost, but not quite, would bind fromn the sharp(ish) angle I had to work with. I ended up using the longer cable, and looped it to keep everything feeling smooth. Not the most elegant solution, but it is functional, and doesn't look hillbilly at all |
03-08-2015, 10:30 PM | #12 |
Re: Throttle cable
I just put a throttle cable on my 87 V10. Two were offered one was 31 inches and the other was 28. The one that was on the truck was a 28 inch cable and it kind of wound around a bit, which I thought was odd. The new one fit the same way....I have no idea why they didn't make the cables so that they were maybe 26 inches....that would have cut out a lot of potential kinks.
If you want I can take a picture or two tomorrow. |
