09-20-2014, 03:16 PM | #1 |
86 K10 Summer Project
I haven't been on here in quite awhile. Here's a truck I've been building in my spare time for a friend of mine.
86 K10. Had a clapped out 350 in it when it showed up. 700r4 trans. 6 inch suspension lift I believe. Plenty of rust of course.
67 Chevy K20 LWB Fleetside project 85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project 86 m1009 blazer, 6 in lift, 35's, driver 69 c10, 307, long bed, 3 speed, driver 07 Dodge 2500, cc, lb, cummins turbo diesel 00 z28 camaro, ls1, 6 speed, rarely leaves the garage |
09-20-2014, 03:23 PM | #2 |
Re: 86 K10 Summer Project
Rockers and cab corners didn't look too bad when I started, until I peeled off the patch panels that were riveted on...
09-20-2014, 03:24 PM | #3 |
More rot
09-20-2014, 03:26 PM | #4 |
More
09-20-2014, 03:29 PM | #5 |
Passenger side rot
09-20-2014, 03:36 PM | #6 |
All the junk cut off the passenger side. Surprisingly the cab supports are all still good.
09-30-2014, 10:38 AM | #7 |
looks great but I don't understand why you didn't remove the seat belts and the 4x4 shifter bezel??? you would have saved time and alot of tape.
10-01-2014, 03:13 AM | #8 |
Second Chance Program
Subscribed! Good work!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
10-01-2014, 09:50 PM | #9 |
Thanks for the compliments.
I believe the bed liner is made by SEM. I'll have to check the can. I was going to take the belts out but the bolts are seized. Tape was faster and a lot easier than drilling out broken bolts.
10-01-2014, 09:57 PM | #10 |
I got the frame all finished up yesterday. Pic isn't the best.
10-01-2014, 10:11 PM | #11 |
The wiring harness was hacked in this thing. I swapped in a good harness from a parts truck. Spent tonight getting all of the lights working.
The high beams wouldn't stay on without holding the switch. I had to replace the switch at the bottom of the steering column. That was fun to get to. The body work is pretty much done. If all goes to plan, the rest of the interior and the jambs are getting painted this weekend.
10-14-2014, 10:32 PM | #12 |
I saved most of your posts because soon i need to venture into the world of rust repair. I have a cab that is fairly rust free. Would I simply be able to cut off the rocker panels and cut out the rusty rocker panels on my truck and just weld them up instead of buy replacement panels?
10-16-2014, 09:10 PM | #13 | |
10-19-2014, 07:32 PM | #14 |
Got the fenders and doors hung this weekend. They're aftermarket and we had a hell of a time getting them to fit. Took about 5 hours of trial and error to get the gaps and body lines to line up decently.
10-19-2014, 07:33 PM | #15 |
Finally starting to look like a truck
10-15-2014, 11:19 PM | #16 |
Looks like its coming along well, figures the bolts might have been rusted
10-15-2014, 11:26 PM | #17 |
Nice work!
10-19-2014, 09:09 PM | #18 |
Robert Olson Transport
Looks real good.. Is your paint a one stage or two?
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
10-19-2014, 09:44 PM | #19 |
Interior is single stage. Outside is going to be base/clear.
10-20-2014, 05:23 PM | #20 |
Sweet!
10-27-2014, 08:28 PM | #21 |
Got the hood on
10-27-2014, 08:30 PM | #22 |
Nice! Going to be crazy to see it all red!
12-08-2014, 01:34 AM | #23 |
i love your truck!
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
12-08-2014, 05:13 PM | #24 |
I really like those inside door panels they look just a little different than the stock ones i think don't they? did the rockers and cab corners go fit in nicely?
12-11-2014, 10:51 PM | #25 |
Yeah the door panels are different from the stock ones. The rockers fit ok. I had to cut about 1/4 inch wide section out of the cab corners to make them fit the door jamb, I guess they're designed to slip over the original corner.
