Speedometer options
I sent my speedometer from my 61 Apache out to get a quote on how much to repair it. The quote was $300.00 , which may be a good price but I am not prepared to pay that much. My truck is not going to be stock or a show truck, more like a rat rod. Does anyone have other options for me that will not cost an arm and a leg and that will give me an accurate reading of my speed?
Thank you |
Re: Speedometer options
if it works at all take some ATF and lube it .....if the odometer is stuck take the shaft out that drives it and you should have a working speedo
I've got a good '63 if it will fit your '61. Just let me know.
Hugh |
#4 | |
![]() Quote:
HTH, sam |
60-66 Nut
If your original speedo isn't repairable by yourself using suggestions above, you should be able to find a good '60-'63 speedo here in the '60-'66 classifieds. Have you tried contacting member TBONE1964 here on the forum? He rebuilds gauge clusters, including speedo's.
I have an extra one out of a 61 gmc. Thought I could modify it for a different cluster but it's not the right size so I don't need it.
Bow tie has them ready to ship for $170
link: http://www.bowtiebits.com/store/stor...Category_ID=74 They also rebuild gauges....
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 09-23-2014 at 09:09 AM. |
I purchased a used speedometer from Hugh in NC. I am expecting delivery tomorrow. Thank you to Hugh and those who offered suggestions.
Get a quote from Williamson's Instruments in Chester, Arkansas.
I just received my worm gear and reassembled my speedo. I lubed it all up real nice too. The odometer now turns as it should and is in sync with my GPS. The speedo now is acting even stranger. Before it would deviated from almost dead on to 100mph and back and the odo did not move at all. Now the speedo won't go above 40mph no matter how fast I drive.
What did I do wrong??? |
#11 | |
Cluster King
![]() Join Date: Nov 2012
For those interested, I have many 1960-1966 Chevy truck gauge cluster parts in my inventory.
A very nice restored 1960 - 1963 speedometer that is checked for calibration, needle bounce and and noise would run $100.00 shipped. Ready to install in your cluster with a 90 day warranty. I stand behind all of my work. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
#13 | |
The metal housing of the speedo I borrowed from a 67 bel air 250 PG. I had it in my parts bin from my first car in 1980. The actual worm gear I bought was the wrong one. I didn't know it when I ordered it. I broke the worm gear that is pressed in and runs off the cable drive gear. The housing from the 67 looked the same. Maybe the drive gear is different ratio? |
I just installed one of the 63 speedo's that TBONE1964 rebuilt. The thing is cherry. Nice job and attention to detail. Highly recommend his work. Good communication and shipping. Sounds like an ebay feedback :O) - however I believe my issue is in the cable. This new unit is doing the same thing the one I rebuilt did. Won't go over 35-40mph even when my GPS reads over 50mph. Could it be the drive gear at the trans? My truck had 3.73's and were swapped out for 3.08's
