Old 09-24-2014, 03:55 PM   #1
62much
62much's Avatar
Disc brake conversion
Well I finally bought another money Pit, 1969 C10 SWB, 350/350. The truck's in pretty good shape, and the PO had put on a disc brake conversion, or at least half of one anyway. The truck was a manual power brake truck, and the problem I see is that he kept the stock Master/booster & prop valve and just made it work... no wonder it doesn't stop worth a damn Now I've done a few disc brake conversion before, but they were manual w/o a power booster, and I just added the new booster with everything else. My question is... do I need to replace the booster along with the Prop Valve & Master, or will the stock booster work. I was hoping not to have to do this again, but you really have to check other peoples work when you buy these old trucks
62much is offline   Reply With Quote
Old 09-24-2014, 04:13 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Disc brake conversion
Booster will work. Youll need a disc drum master cyl and prop valve. Cpp has a good one theres a new prop valve on here for 75.00. And youll have to replace the front lines as well as theyre different and wont screw imto the new prop valve.
1967custom
michael bustamante is offline   Reply With Quote
Old 09-24-2014, 04:21 PM   #3
62much
62much's Avatar
Thanks, thought it might but wasn't sure. I have a prop valve left over from a previous build, just need to get a new master.
Old 09-24-2014, 04:38 PM   #4
62much
62much's Avatar
I looked up a master cylinder for a 72 and it shows a 1.125" bore. and the one for my 69 as a 1" bore. Do I need to get a different rod too???
Old 09-29-2014, 12:30 PM   #5
62much
62much's Avatar
bustamante:
Do you happen to know if I need to replace the rod in the OE Master, the size are different between a Manual Power Master and a Disc Master Cylinder.
Thanks,
Clay
