Old 09-28-2014, 08:52 PM   #1
jh68c10
dropped spindles
I have a 74 c10 front suspension under my 68. But I got a deal on 72 drop spindles. What do I need to change to make them work? Thanks.
jh68c10 is offline   Reply With Quote
Old 09-29-2014, 01:40 PM   #2
Pro Performance
Pro Performance's Avatar
Re: dropped spindles
You will need to change the upper ball joint to a 71-72 version, which can be bolted in. The lower is the same from 71-87. You will also need to swap to a earlier 71-72 tie rod outer.
Pro Performance is offline   Reply With Quote
