09-28-2014, 11:27 PM | #1 |
track video of my 71C10 turbo 6.0L
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs) 00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs) |
09-28-2014, 11:31 PM | #2 |
Re: track video of my 71C10 turbo 6.0L
09-29-2014, 01:39 AM | #3 |
Lots of mph... no reason it can't go low 10's with a verter swap or just plain better 60'
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
09-29-2014, 03:47 AM | #4 |
meowMEOWmeowMEOW
Is that supposed to be 12psi? Sounds like WAY more than the "2 psi" the top of the vid says.
thing rips tho
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-29-2014, 02:58 PM | #5 |
Boosted Member
Less hippie music, more spooly noises!!
LOL@ getting kicked off the track at the end. Nice work. lol
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
09-29-2014, 06:26 PM | #6 |
meowMEOWmeowMEOW
Maybe I need to put the down...did I miss something?
09-29-2014, 06:59 PM | #7 |
3.25 " you are goin' home" after asking for another run
GOD BLESS AMERICA! |
09-29-2014, 07:16 PM | #8 |
Hey "wasted income" dude.... small world....My buddy nater Leman just show me a few pics of your blaze yesterday. Looks awesome nice job.
09-29-2014, 07:42 PM | #9 |
Nice setup. You can definitely knock off at least 1/2 second with that mph especially if you can get up on boost before launch.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
09-30-2014, 08:22 AM | #10 | ||
Boosted Member
I've seen the hillbilly transbrake via Denmah on 'Tech. Never tried it though, as my hydroboost and 2 step let me build more than enough to shred the Mickeys from a dig. Bigger front tires might let you hold it more before it pushes? That's pretty generous! Our local track...you run too fast...you're gone.
10-01-2014, 06:17 PM | #11 | |
09-29-2014, 02:24 PM | #12 |
I am guessing he means he footbrakes it to 2 psi? But yea don't know what is full boost is?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
09-29-2014, 06:38 PM | #13 |
I was wondering about the 2psi bit too. Nice setup.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
09-29-2014, 07:03 PM | #14 |
Yea launching at 2psi off the foot brake. I had the lightest tial spring in the gate (5lb) boost was very inconsistent 5lb to 15lbs during the passes. Im adding another waste gate and I'm looking at doing a mod to allow me to manually force the 80e into 3rd by grounding the solenoid then interrupting the ground to launch in 1st. Forcing the 80e into 3rd I will hopefully be able to make a lot more boost on the foot brake@ launch. Basically making a "farmers transbrake".
Will be back at the track in 2 weeks for another test and tune to push it a little harder. And yes all they allow 3 passes under 11.50' before getting the boot. (No cage)
10-01-2014, 11:12 PM | #15 |
meowMEOWmeowMEOW
12 bolt rears are better than many people give credit, since the "go big or go home" answer will ALWAYS be a custom 9".
In a drag car, an 8.8 or 9" has advantages, not in the least being the quick change gear sets. A 12 bolt however is a fine trans for most folks. Its fairly beefy from a build standpoint, unlike the 10bolt. The c clips will always be an issue. I have a set of good axles in mine, and that takes a big chunk of the worry out right away. I'm still concerned about grenading the whole carrier or something, but not on the stree.
10-02-2014, 12:19 AM | #16 |
I recently moved to a 9" but 1.43 60's spinning on the 100 hit, well I think the truck 12 bolt was on borrowed time with the full N20 kit. It had moser axles, C-clip eliminators, auburn posi.
I think a properly built truck 12 bolt could live at mid/low 1.5 60's..
10-02-2014, 08:28 AM | #17 |
It's a stock12 bolt with moser axles and a mini spool. No issues so far. It's been about 2 years with this power. The 80e is a lot easier on the rear than the Muncie was.
10-02-2014, 03:26 PM | #18 | |
Thanks everyone for the info on the 12 bolt everyone who replied seem to have good built trucks ive read most of your builds and learned alot. |
10-02-2014, 10:40 AM | #19 |
Boosted Member
I too have been putting 700+ whp through my 12 bolt for the past couple years, and 500+ for the 3-4 years before that, all of them on a drag radial. It's bone stock with the exception of a chromoly 1350 yoke, and an Auburn posi. Even has the stamped steel cover.
I have a feeeling it is next to let loose...but it certainly doesn't owe me anything at this point, and I agree with Brew City that it's a lot stronger than people will have you believe.
10-04-2014, 01:57 PM | #20 |
I'm running a car 12 bolt with Mark Williams spool and axles on a big slick (32x14x15). Truck weighs 3900 race weight w/driver and turn 1.40 60' times like clockwork off the footbrake.
12 bolt rear ends will definitely take the abuse and cost less HP to spin than a 9" Ford. Only advantage to the Ford rear swap might be availability of parts or second hand pieces.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive Interior 1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories My momma took me off the bottle years ago..... |
10-12-2014, 08:23 AM | #21 |
UPDated Track Results 10.1@133mps track video of my 71C10 turbo 6.0L
after some more fine tuning and addition of the 3rd gear 80e mod. my rig went 10.1@133mph. 60'@1.54. Launching on the foot brake @10#, then full boost 17#
Ran 3 solid 1/8 mile passes all at 6.6 or 6.7 @107..then slamming the brakes Only got to run this 1 10.1 pass out the back door this time before getting my wrist band cut...again new video coming. here is the slip#695
10-12-2014, 12:01 PM | #22 |
Nice times pm sent
10-12-2014, 10:23 PM | #23 |
New Track Video
Video From yesterday
http://youtu.be/Wsn0bjM2tdM
10-12-2014, 11:21 PM | #24 | |
Re: New Track Video
10-13-2014, 09:06 AM | #25 |
Boosted Member
Hot damn! Nice work.
