10-01-2014, 02:56 PM | #1 |
40gal Suburban fuel tank install.
So i will start by saying that this may not be right, or even the best way, but this is how i mounted my 40gal suburban tank. And also this is my first attempt at a wright up so I apologize if its a bit scattered.
Starting with my 1991 R/V Crewcab conversion LWB, I removed the passenger side rear shock mount because it will be in the way of the tank. I then moved the rear crossmember as far back as possible and added a piece of steel to give the tank a little more to rest on. You can see from the pic how far back I moved the crossmember. Then i held the tank up with a floor jack and go it level to see what i would have to do for the support that the front of the tank would rest on. Worked out that 2" square tubing sat the tank almost perfectly level, so i drilled and welded some sleeves in the 2" square and bolted it in. To secure the straps i used a piece of angle iron running across the frame rail , I mounted mine close to the tank to make installing the tank less of a hassle. I hooked up the straps and tightened it down. For clearance here is a pic of tank to rear diff cover clearance. I will have to take a small section out of one of the ribs running under the bed floor. This is because the top of the tank humps up and the fill breather tub might make contact. My plan for the fuel door is all based on speculation right now because i have not started on it and I am 8000mi away. But i plan to move the fuel door to behind the rear wheel well like it would be on a suburban. I don't foresee any problems with this but I will have to check when i set the bed back on. I also completely bypassed the switching valve switch and wired the pump into what would have been the passenger side tank. Everything seems to work good but i have to finish my outboard shock mounts before i can cruze around with it. For now it sits like this until the middle of October. I'm excited to try it out but less so at the thought of spending about $130 bucks to fill it up!
1991 Chevy Crew Cab R3500 to V3500 Conversion Project: Build Thread Photo Bucket Pics You cant fix stupid, and stupid hurt! Rules to live by. |
10-02-2014, 03:44 PM | #2 |
Re: 40gal Suburban fuel tank install.
Cool, thanks for writing this up!
I was planning on doing something similar to my '91 2wd, but was thinking using a Blazer tank might be a better alternative fit wise; but I am also planning a making it a shortbed too. I have a '91 Suburban to use for parts though, so it might just be easier to use whatever is under the Suburban!
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
10-02-2014, 10:47 PM | #3 |
For a short bed a 25gal blazer tank should fit and maybe even a 31gal suburban tank. If you have a parts suburban i would use everything you can, rear crossmember etc. I had cut up a 2wd crew cab so i had a some of those parts laying around so Just used them! Good luck and let me know how it goes!
12-18-2014, 02:45 AM | #4 | |
I have a custom 45 gal tank in the back but Iīm affraid that the hitch will not clear it when the first mounting hole needs to go in front of the two bolts holding the bottom of the crossmember in place. Were you able to reuse factory holes in the frame for the hitch or did you have to drill all of them yourself? Does your hitch use 4 bolts per side??? Thanks for any info you can give me!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
12-18-2014, 10:08 AM | #5 | |
I will grab some pics when i get home around xmas but the flange around the tank is close to the body of the hitch but it clears.
12-18-2014, 11:27 AM | #6 | |
Thanks for the info! Looking forward to the pics!
01-10-2015, 01:08 PM | #7 |
Sorry for the delay been busy around here.
Here is a pic of the gap between the tank and receiver. It's close buy it clears. I had to clearance the corners of the receiver to clear the tank crossmember bolts. Here is my amateur attempt at body work. I moved the fuel door to work with my suburban tank, now I have to modify a fill neck to work with it.
02-09-2015, 03:35 PM | #8 | |
Do you have a detail pic of how you mounted the hitch with the rear crossmember bolts "in the way"? Iīd like to see that. Maybe a shot from the bottom up where the hitch meets the frame!? Thanks!
01-10-2015, 03:03 PM | #9 |
What're the dimension differences between the 25, 31, and 40 gallon tanks? Does it hang down much below the frame? My C20 only has a single tank on it, below the passenger side, and I'd like to swap it out for something a little bigger, farther back would be nice too.
1973 C20, 350/350 |
01-10-2015, 09:13 PM | #10 |
Here is the info I used. For a long bed 2wd I would not go with the 40gal tank just because you may have clearance problems between the tank and the diff. a 31should be fine though.
01-10-2015, 10:31 PM | #11 |
Looks good. Got a ? If i want to use the 25gal tank for rear an have a ls swap. Which tank should i get. An 87+ burban. Those had the baffels an pump for 60psi correct?
01-11-2015, 12:03 AM | #12 |
Second Chance Program
Chevy-fun, 87+ did have baffles. But you have to get an ep381 or equivalent fuel pump. The stock ones in the 87-95 TBI do not supply enough pressure.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
01-11-2015, 12:18 AM | #13 |
X2, I would get a tank from a 1991, they should be the same but that is my preference.
01-11-2015, 02:14 AM | #14 |
Thanx for info
