10-03-2014, 04:14 PM | #1 |
1/2 ton vs 3/4 in cab fuel tanks
I just bought a 71 3/4 ton 2wd truck that hasn't been started in 8 years. The entire fuel system must be replaced due to the great fuel we have to work with these days. In looking at a new tank I can only find 1/2 ton tanks. I didn't know there was a difference.
I know there's are different versions due to the emissions but is that the only issue I have to worry about? Can someone shed some light on this for me? Thanks
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI. 2007 Chevy 2500HD 4x4 Duramax 1970 Chevy K20 (SOLD) 1972 Chevy C15 (1/2 C10, 1/2 c20) 1970 Chevy C10 (parting out) |
10-03-2014, 04:30 PM | #2 |
Moderator
Re: 1/2 ton vs 3/4 in cab fuel tanks
There is no difference between 1/2 and 3/4 tanks. 72 tanks had EEC but that is the only difference I am aware of.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
10-03-2014, 04:34 PM | #3 |
Thanks for the reply. I'm going to go ahead and buy the 1/2 on tank but both companies I talked with said they will only say it will fit a 1/2 ton. Both said they are looking for a 3/4 ton supplier but cannot find one.
Thanks again.
10-03-2014, 04:43 PM | #4 |
I don't know what your ultimate goal is but have you considered relocating it inside the frame?
If not I'm sure you could source a good one someone has pulled |
10-03-2014, 04:53 PM | #5 |
I've thought about it but I'm kind of a purist on the old trucks.
I may try to coat the tank and reuse it but its pretty nasty. The sending unit has rusted so much it was hard to get out. I've never seen one do this before.
10-03-2014, 05:18 PM | #6 |
You might want to try a Spectra tank from that outfit in Canada. I nearly bought one myself but I ended up having my tank cleaned and "renewed" at a radiator shop. I'd also try GMC Pauls and Classic Heartbeat.
If you want to stay original, I'd suggest getting a tank off of a member. Several people on the boards have their old tanks and might just give those away. I'd get it shipped in a wooden crate though. |
10-03-2014, 07:21 PM | #7 |
member #16
Did the 3/4 ton trucks have EEC? I know they didn't have smog pumps. At least not in CA.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
10-03-2014, 08:51 PM | #8 |
Cool Truck
I believe I remember reading that the 71-72 3/4 tons use the older non EEC type tank where as the 1/2 tons switched
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
10-04-2014, 07:11 PM | #9 |
concur - 3/4 ton trucks were non-EEC through at least 72. If you are installing a 1/2 ton tank from a 70-72 (I BELIEVE those were the trucks with EEC), make sure you use the correct filler neck grommet. I am pretty sure the EEC tanks had a 2" i.d. grommet whereas the non-EEC tanks had a 1/5" i.d. grommet. However, IF this were the case, I find it hard to believe that nobody carries a "72 3/4 ton tank".... LMC sells a 67-72 non-EEC tank and that should meet your needs - and note that they do NOT state 1/2 or 3/4 ton for the non-EEC listing, whereas they do list a 70-72 EEC "1/2 ton" tanks separately. Personally, I'd still lean toward rebuilding or finding a decent one in a junkyard and coat the inside. Nothing (for me) ever seems to be "quite right" when I order stuff like this from LMC or several other mfgrs. It is just a tank, so I think that with the correct grommet, as long as you purchase a non-EEC tank, you should be good to go.
10-04-2014, 07:20 PM | #10 |
Try Rock Auto. They sell Spectra Premium, which has received favorable comments on this forum, at a pretty decent price. I don't have any personal experience with them, however.
10-05-2014, 01:06 PM | #11 |
Thanks everyone for the replies. I' m going to "renew" my tank and hopefully that works out.
It is a non-EEC tank, I do know that for sure. This truck is from central Ohio and winters has played hell with the fuel and brake lines. I'm going to start a new thread with some questions about that. Thanks again!
