Old 10-07-2014, 07:27 PM   #1
fine 67
Junior Member
door problems
i'm just about ready to kill my blazer or use a porta -power the windshield /cowl. I changed the rockets with gm nos the floor and rocker boxes are mint .was to dumb to brace it!!! the pass door is way to tight in the back but the door is almost touching the windshield frame kill it/gas ax /porta-power need help thanks mark
fine 67 is offline   Reply With Quote
Old 10-07-2014, 08:21 PM   #2
seventyjimmy
Re: door problems
the door, is it close at the top and bottom toward the rear?
seventyjimmy is offline   Reply With Quote
Old 10-07-2014, 09:12 PM   #3
fine 67
Junior Member
Re: door problems
door gap is super small on latch side and on vent window frame to windshield frame die nuts to rocker and front and rear edge are right on thanks
Old 10-07-2014, 10:45 PM   #4
Dale99
Re: door problems
yep, had that problem when I did my first one. Second one I welded in braces in 2 or 3 spots.
Dale99 is offline   Reply With Quote
Old 10-08-2014, 01:14 AM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: door problems
You probably need new body mounts. I've never done it, but I have read that you can shim it and adjust the door gaps.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-08-2014, 06:58 AM   #6
seventyjimmy
Re: door problems
What was the door gap like before you started? These vehicles are like any other convertible the rocker, floor, boxes, jams are the only structural support. unlike a hard top vehicle. If the gaps where ok before the rocker install you may have to loosen the body mounts in order the finesse the gap. I would over correct to allow for the settling when mounts are retightened.
Old 10-08-2014, 10:49 AM   #7
jaros44sr
jaros44sr's Avatar
Re: door problems
You might try closing the door on a piece of wood, or do what bouncy said
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-09-2014, 12:43 AM   #8
MuppetMan
MuppetMan's Avatar
Re: door problems
Let's see some pics. I may be facing the same issue.. Where is it too tight exactly?
MuppetMan is offline   Reply With Quote
Old 10-09-2014, 09:43 PM   #9
IronCanine
I'm trying....
IronCanine's Avatar
Re: door problems
This is what we looked liked before disassembly. Our front cab supports were bad. The floor and rockers needed replacing but weren't structurally toast by any measure. Replaced the body mounts and fixed the metal. No serious massaging. The gaps were remarkably better when it started going back together. Most of it was in the body mounts.
IronCanine is offline   Reply With Quote
Old 10-10-2014, 04:24 PM   #10
IronCanine
I'm trying....
IronCanine's Avatar
Re: door problems
I took this picture today. Now I don't want to paint a false picture. This truck had had some collision damage and very poor repair, along with completely disintegrated body mounts and rusted/broken cab mounts. So there were a lot of things contributing to our generalized ill-fitment. And while things fit much better after replacing the mounts (there was at least room for a door to exist on the passenger side) there seems to be continuous gap work on these, adjust, re-adjust...but I do think in our case the biggest problem was the cab supports and rubber body mounts. We went back with rubber btw.
