10-09-2014, 10:33 AM | #1 |
LS Stuff
Once again asking for more advice. Trying to figure out the best motor mounts and headers for a 6.0 swap. I have looked throughout the forum and now my head is spinning at all the different choices. Looking for people that have experience with whatever they are recommending and any problems they have encountered. Thanks in advance.
10-09-2014, 10:52 AM | #2 |
Re: LS Stuff
I cut a set of adapters from steel plate that sets the stands in the six cylinder location and used 2010 stock Camaro manifolds. The particular setup I used required cutting and welding the stock engine stands, but it looks like using the mount pattern that puts the stands in the stock location would have avoided the need for this. The variant I used, however, would allow using a stock A/C compressor location if I can figure out what to do for the line fittings to clear the front framerail. See the build thread in my sig for details.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
10-09-2014, 07:39 PM | #3 |
Re: LS Stuff
I used ditry dingo adjustable slider mounts
10-09-2014, 08:51 PM | #4 |
Re: LS Stuff
How did they work for you?
10-09-2014, 09:12 PM | #5 |
Re: LS Stuff
They worked fine stock 71 mounts bolted right up to them. The stock ls ac compressor wouldnt fix down bottom still had to shorten my drive shaft no biggie
10-09-2014, 09:46 PM | #6 |
Re: LS Stuff
What headers did you use and did you have any fitment issues?
10-12-2014, 10:33 AM | #7 |
the boat guy
Re: LS Stuff
Best? Custom built specifically for your truck here you want your egine located. Everything else is a compromise, most people like the adjustability of dirty dingo mounts. Plenty of people running car manifolds, swap headers, and some car manifolds, or flip them over and run a front mount turbo.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
10-12-2014, 10:42 AM | #8 |
Re: LS Stuff
I used trailblazer ss exhaust manifolds look juat like the hooker headers the sell clear3d my mounts and frame just fine
