10-09-2014, 01:01 PM | #1 |
Headlight thread
I am looking for some ideas of what some people are running out there for the 7" headlights on our trucks
I am thinking about the stock headlights from a new Jeep Wrangler or possibly even running a set of LED headlights like the company Trucklight offers. I just don't want to run the cheap plastic ones from eBay.
1970 Chevy C10 Fleetside SWB 1998 Dodge Viper RT10 1999 Harley Road King 2006 Ford F250 CC SWB 2008 GMC Yukon Denali My Build Thread |
10-09-2014, 02:02 PM | #2 |
Re: Headlight thread
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
10-09-2014, 02:08 PM | #3 |
70+ ( Old Skool Club )
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-09-2014, 02:29 PM | #4 |
20' Daredevil (Ret)
I'm partial to Cibie E-codes. LEDs look promising but too expensive last time I looked.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-09-2014, 02:34 PM | #5 |
Parts and more parts
How serious are you about headlights. I put the square ones in my 84 to replace the factory weak link lighting and I really like them. These are metal housings with aftermarket bulbs installed for lighting. You can go to a lot larger wattage with these.
http://www.visionxwholesale.com/7-ro...am-pro-07hilo/
Frank |
10-09-2014, 03:15 PM | #6 | |
10-09-2014, 02:45 PM | #7 |
Moderator
I post this every time a headlight thread pops up:
SilverStar headlights (regular old sealed beam), and a relay upgrade harness (I have the one from LMC but you can make your own). Phenomenal difference and very cost effective.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
10-09-2014, 03:15 PM | #8 |
Do you have any pics of before and after?
10-09-2014, 03:31 PM | #9 |
Moderator
Nope, I did this several years ago.
10-09-2014, 03:27 PM | #10 |
This is what I did, very happy with the results.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
10-09-2014, 05:07 PM | #11 |
I totally agree, had them on my truck since 2005 and they worked perfect with lots of visibility. Did my own headlite relay harness from scratch with relays from a wrecked 90's Dodge Caravan.
10-09-2014, 03:59 PM | #12 |
X2 on the headlight harness, you won't regret it.
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
10-09-2014, 04:19 PM | #13 |
US Army Veteran
I recently went through this on my truck and spent a lot of time researching on the forum. Jeep lights, with modified pig tails. Cibies, hellas, Sylvania Ultras.
Spent several weeks of spare time, looking up lights on google to see lighting pattern. I came across this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=436955 and ended up choosing this route for the upgrade in my '72. I had already installed a relay harness last year, so that part was done. I ordered: Hella 002395301 (About $80) from jegs on ebay. Had the best price and knew they would ship fast. These do come with bulbs, but I wanted to use the Xenon bulbs used in that thread, so I picked up: Hella H83140272 9003 HB2 High Performance Xenon Blue Halogen 12V 60/55W Pair (about $25) When they arrived, I opened the headlight boxes first. There is a latch to hold the bulbs in place, that simply lifts up. I replaced the stock bulbs in each, with the Xenon bulbs, making sure not to touch the bulbs with fingers, as instructions recommend. Installation was simple. In fact, for all the things I've done on my truck over the years, this was one of the simplest and hassle free installations I've done. I expect some sort of hassle, but there was none. They fit in the buckets with no modifications, no wiring hassle and the stock/factory plug fits right in. Visibility difference was night and day. There is a definitive cut off that keeps the light focused below eye level. Lights are much closer to white when on, vs the typical yellowish tint. Visibility is much clearer on low beam. When on high beams, I was blown away by how much farther and clearer I could see. High beams were important, because I drive early in the morning in an area where there are lots of wildlife, especially deer. Hope that helps. There's a lot of options. After looking at them all, this seemed like the most cost effective way to get the best lighting solution without a lot of hassle. Probably the best money I've spent on my truck so far!
1972 C10 Highlander - The making of a daily driver |
10-09-2014, 05:18 PM | #14 |
I had silverstars on my 84, thet are an improvement, but I want see the deer before he comes out, instead of after he hits my truck. Yes, get a quality wiring harness and tie it to the battery direct with the headlight switch controlling it. More voltage available to the lights.
http://innovativewiring.com/
Frank |
10-09-2014, 07:33 PM | #15 |
08 wrangler headlights
10-09-2014, 07:56 PM | #16 |
Was curious if anyone used these. They look pretty cool
http://www.gelighting.com/LightingWe...-July-2013.pdf |
10-10-2014, 01:42 AM | #17 |
How was the install of those? Pretty straight forward or did you have to modify some stuff
I would guess that they should be straight forward because it's a 7" light
10-09-2014, 08:02 PM | #18 |
I've got halogen bulbs in mine, along with relays, and it will blind you.
71 K20 64 GMC mud truck |
10-09-2014, 11:01 PM | #19 | |
I built my own harness.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
10-09-2014, 11:10 PM | #20 |
I have an old set of Hella lights that I've had since 1974. They have been on the shelf for decades so I'm looking forward to seeing how they work with the LMC relay harness I'm installing.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
10-10-2014, 02:32 AM | #21 |
I just did last night 7" glass face conversions, with 35w 4300k hid bi xenon kit, my cost with wholesale account was $60 including lenses and they give an 18 month warranty on the hids
10-10-2014, 10:24 AM | #22 |
Keepin an eye out
Subscribed/
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
10-10-2014, 10:32 AM | #23 |
Post a pic of the finished product and possibly a link where to get them.
10-10-2014, 11:34 AM | #24 |
When I can afford it I'm going with retrofit.com They have the best of the best for HID lighting and they now offer the 7" kit. Very excited. Can't wait to get it.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
10-10-2014, 12:51 PM | #25 |
Ugh, here we go again....
HID, terrible light source for night driving, throws lots of light in a very unfocused way, that is a color temperature that tricks your eyes to think it's daylight, so it destroys your nighttime peripheral vision, has no focused distance throw, it's expensive, it's very disruptive to oncoming drivers, has slow startup times, and was only ever implemented in vehicles to reduce heat in small volume aerodynamic housings constructed primarily of thermal resin plastics. A stop gap technology that will be completely obsolete in new cars within 10 years or sooner, replaced by emerging LED technology. LED, a ways away at this stage, just starting to become a high performance alternative for serious automotive lighting. Again addresses the small volume thermal plastic housings. Has some serious aiming and projection issues, very difficult to lens focus, also difficult to focus through a reflector, must be focused via arrays of narrow view chips specifically engineered for the housing. The most efficient light output color profiles have the same issues as HID and promote peripheral night blindness. Virtually all aftermarket headlight replacement units for vintage vehicles headlamp sizes are essentially the equivalent of strapping a couple tactical flashlights to the front of your vehicle. This probably won't change anytime soon, if ever, as it's a huge development effort to produce the packaging to make LEDs perform well, it would require a manufacture to sell tens of thousands of units to pay back the development and manufacturing cost of committing a production line to the custom chip packaging required. There is a reason why LED lighting on high end cars is an expensive option and in racing is limited to teams with huge budgets. If you are simply looking for lighting at the level of a Prius or Harley or an American Soccer Mom SUV (ie: tactical flashlights) or anything engineered to be good enough for a vehicle that will likely never exceed posted speeds at night, well I guess it's an option. Oh and LEDs produce a very specific color temperature spectrum, enough to perceive white or whitish but actually lacks huge chunks of the gradients of colors in-between. So if you look at a "White" LED light source through a prism it isn't a rainbow, it's a few narrow stripes. What's lost in human vision with this is the interaction between cones and rods in your retina, depth perception and contrast perception suffer because of this. Halogen, still the predominant night racing light source, focuses very well by reflector or lens. Good compromise in nighttime color, limits peripheral night blindness, very good anti dazzle qualities when used in the proper reflector lens combination. Traditional halogen skews color temperature away from blue hues (what causes nighttime peripheral blindness) and allows both cones and rods in your retina to fully function at night, giving you good contrast perception, good depth perception, less particle bounce back and less glare and haze reflected off of objects. Overall far less long term eye strain in long distance and critical nighttime driving. Properly focused can project beams to great distances. The downside is they are hot, high wattage, and need a substantial reflector to dissipate heat. High output halogen needs air movement for cooling and reflectors need to be either constructed with substantial volumes or out of heat tolerant materials like metals and glass. Focus is done by lenses and reflectors and may not be as clean looking. Low beams that are used in often stopped or slow speed conditions that limit cooling airflow are typically limited in wattage. The bottom line, HID is a waste of time that offers nothing to a vehicle with big round reflectors other than making you *feel* like it throws a lot of light because you see a bunch of light bouncing back at you off of stuff in the air and near field bright objects. LED has promise that may or may never translate to vintage aftermarket form factors, but regardless still suffers from a lot of human vision issues. Last edited by skorpioskorpio; 10-10-2014 at 04:18 PM. |
