4.8l ls motors, who has one, how do you like it?
Hey guys, I was perusing CL today and ran across a 2001 silverado with a smoked trans and a 4.8l ls motor for $850. I have read these are de-stroked 5.3l. I have a 5.3l in my 2001 Sierra and love it. Whats the power difference in the 4.8l, Is it noticable? I would consider doing this swap into my c10, but was wondering if anyone had done it (I'm sure they have) and if you like it?
Thanks, Mike
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
![]() Join Date: May 2012
Re: 4.8l ls motors, who has one, how do you like it?
Lots of 4.8 swaps. Yes they share the same block. Same everything I think... Just a shorter crank in the 4.8.
McBassin did a 4.8 in his build. His build thread is named "69 Shortwide" and stays near the top in the projects and builds threads if you want to check it out. I'd run a 4.8 without a doubt if I found a deal on one. COPY AND PASTED: Power ratings ranged from 270-290hp net and 285-305 lb-ft for the 4.8L, and 270-305hp net and 315-335 lb-ft for the 5.3L. What should be evident is that the two actually produce similar peak horsepower outputs, but the larger 5.3 will always offer more low-speed grunt Read more: http://www.superchevy.com/how-to/eng...#ixzz3FmFK8z1d |
Get in touch with daaaanz67
We live less than an hour from you and he has one in his and did a killer job on it. Plus he knows all the go to people in the area for tuning and upgrades. I'm actually thinking I will do the same in mine. Ideally I would love a 6.0 but that can come in time my main thing is getting my truck setup and switched over so in the future all it will be is a long block swap. I will also be hooking mine up to the th350 |
That's me. She's an absolute rocket a little less torque than the 5.3 but I would run another one in a heart beat. I was able to attend the c/10 get together this last Sunday in A****er and what a joy to really open her up on 99. Nitis thanks for the comps, appreciate it.
My daily driver is a 2006 with a 4.8 runs super smooth with plenty of power, great motor
If you are building a cruiser the 4.8 is perfect, not quite the power of a 5.3 but will do a little better on gas.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#7 | |
My friend has one in his newer truck and even tows an enclosed trailer to the track with it no issues. Has plenty of go
Oh my..... so I started googling "turbocbarving a 4.8l and found this article.... take the ti.e to read jt because it will change your mind about looking for a 6.0l for $2k
http://www.hotrod.com/techarticles/h...g_bang_theory/
That article has been making LS fans since it hit the printer.
All I can say is just think of the LS as a small block Chevy with the inherent design flaws fixed. Great, great gift to hot rodding from GM. |
#11 | |
All about them K’s
![]() Join Date: Jun 2014
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
I think it is a great motor.
These guys where happy with the power out of there 4.8. Video #1. http://www.powernationtv.com/episode...ls-tech-part-1 Video #2. http://www.powernationtv.com/episode...ls-tech-part-2 |
well, I for one have developed a new plan for my truck... first, 4.8l ls because it can turn amazing r's. Then, once I have the money, TURBO!!!!
#14 | |
Spend your money on: 1) Fuel System 2) Tq Converter 3) Trans 4) Tune I've got a 5.3 LM7 with LS6 cam, PAC1218 springs, BTR 7.425 pushrods, ching-chang Ebay head studs, LS9 head gaskets, all ready to install. I'll be making my own truck manifold hot side and using a PT7675CEA turbo. All on E85 with a 4L80E, I'm going for daily driver manners (which I use the truck for a lot already!) and ~650rwhp. But believe me, the engine is the cheap and easy part. |
#15 |
I would caution 3.07 gears if running 700R or 4l60. In town I manually down shift out of over drive. Great highway gears though. My tire diameter is approximately 27". Just speaking from experience 3.42 or 3.73 would be a better choice.
#16 |
the boat guy
Lsx willys is running a 4.great. check out the denmah turbo kits and youtube videos.
Crusty nova is running a 5.3. Leroy brown has had several ls engines and has gone very quick for cheap. Agreed with the engine being the cheap part of a high hp ls build. My 4l60e can't even handle my right foot with a stock 5.3.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#17 |
I'm in the middle of an 4.8 swap in a 85 c10. It should be way cool. PCM of NC cam kit and Holley EFI.
