10-14-2014, 11:38 AM | #1 |
Whine from the carb
There's a high-pitched whine coming from my Edelbrock carb, especially when the engine is idling. The noise dies down a bit when I accelerate. I attached a picture. The whine seems to be coming from the part with a small gap in it (choke assembly?) that is below the carb. The black part with the old triangle shaped gasket. What is this part called and what's it function? Should I probably replace? Any help is appreciated. This board and the venerable board members are so helpful as I'm replacing all the parts on my 67 c10.
10-14-2014, 12:03 PM | #2 |
Re: Whine from the carb
Eddy carb needs an adaptor plate and gasket to fit on your stock intake.
Sounds like you have a vacuum leak. |
10-14-2014, 12:07 PM | #3 |
So you think the leak is between the carb and the stock intake? Should I just remove the carb and put a new plate and gasket in?
10-14-2014, 12:22 PM | #4 |
You need a spread bore to square bore adapter. mr. gasket 1932 or edelbrock 2693
10-14-2014, 03:04 PM | #5 |
Will that adapter cover the bolt holes left when I remove the old part?
10-14-2014, 03:27 PM | #6 |
You should pull the carb off and see exactly what you have for gaskets before buying an adaptor.
Take some pics for us. You might only need a new gasket. |
10-14-2014, 04:01 PM | #7 |
It seems you have a later model manifold. First see if the gasket under the triangular plate is leaking. It is an EGR block off plate.
10-14-2014, 04:04 PM | #8 |
OK. Will pull off the carb and see what I"m dealing with. The engine is a mid-80s Chevy/Pontiac, I think. v8 350. I replaced the distributor and there was a 5 15 1986 etched into the coil, which makes me think the truck's motor was replaced around then. Thanks for the help. Will post pics with the carb off.
10-14-2014, 06:01 PM | #9 |
I'm not exactly a hot rod guy. I just like driving an old truck on the weekends. So would I be making a mistake to simply replace the EGR gasket and plate?
10-14-2014, 09:38 PM | #10 |
10-14-2014, 06:17 PM | #11 |
Go for it!
Might be the vacuum leak. Leave the carb alone for now. |
10-14-2014, 06:48 PM | #12 |
hey Okie ,
show us some pics of your ride as well, greetings from Bigmac73 , I grew up in Moore,Ok
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
10-14-2014, 09:40 PM | #13 | |
