Squealing kind of noise
I put a new 350 in me truck last month and finally got to drive it around. Well I drove it on two short trips and all was good. When I went to drive it the third time I was getting a loud squealing type noise but only under accelerating. I checked the headers and the driver side one was lose I tighten it up but it still makes the noise but I don’t think it is as loud now. I got new gaskets on the way to work thinking I may have blown that one out. Is there anything else I should check if that is not it?
I also read that it could be the speedo cable. I did not think about looking at that when I was driving but I do know it use to bounce a little around 20-30 mph. The 350 has a bigger cam, roller rockers, and Pete Jackson gears. Its in a 1986c-10 Thanks Evan |
Re: Squealing kind of noise
Good Morning,
You may have answered your own question. A geared timing setup can make quite a bit of noise especially if your unfamiliar with their sound. Also check your belts. Rub a little soap on the top while the engine is running. Have a Great Glorious Day! Terry |
I though about the gears also but it seems like a higher pitch sound. The first few starts the starter was acting like it was hanging up a little so I am going to check that after work also.
thanks Evan |
78K & 79C Jimmys
A loose power steering belt can squeal so can a water pump bearing,may want to check those
water pumps can stop squealing after a engine start. sometimes a broom stick moved from each part to ear can narrow it down
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Thanks Motornut I will try the broom stick thing. I hope it is not the water pump it is a new team G water pump the guy put on be for he sold me the motor.
I found the sound. I feel kind of dumb. I did not know a flex plate really flexed. When I put on my mini starter I did not measure it just seen that it was not touching. I guess when I hit the gas it was close enough to touch. Shimmed the starter and all is good.
Thanks again Evan |
Doing Dumb stuff is one way to learn, just learn from it. If not people will think you're stupid. Don't ask how I know....
I really did not want to put what it was but I figured it may help someone else.
78K & 79C Jimmys
I had to remove them on mine PO put in to fix the mashing of gear teeth,when i got it
I removed it,and replaced the flex-plate,its better now on the truck it was hard to tell,but compared to the old one... it's mentioned the gap is as little as a paper clip,when properly meshed
