Old 10-18-2014, 02:18 PM   #1
Mv7fd
Thermal vacuum switch
The thermal vacuum switch broke on the intake manifold where in the world can I get a new one or is it even necessary
Mv7fd is offline   Reply With Quote
Old 10-18-2014, 10:42 PM   #2
Dead Parrot
Re: Thermal vacuum switch
I found a couple at the local pull-a-part for about $1 each. They seem to be mostly a discontinued item at the local parts stores. I think most of the GM versions are basically the same even if they may look different. So check all GM vehicles, not just the trucks. I found one in a front wheel drive car.
A properly working Thermac system does help the motor warm up faster and helps prevent carb icing when the air temps are between 30 to 60 or so and the humidity is high. Once the motor is fully warmed up, it shouldn't be needed any more. If you are having issues with the motor wanting to die/ stumble or idle poorly after driving a mile or so, a broken Thermac system might be the problem.
Dead Parrot is offline   Reply With Quote
Old 10-18-2014, 11:13 PM   #3
rich weyand
rich weyand's Avatar
Do you mean on the intake manifold, or on the air cleaner body?
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 10-19-2014, 07:19 AM   #4
Mv7fd
On the intake manifold. I called napa and a couple other places no one has them they also said about being different colors
Old 10-19-2014, 08:49 AM   #5
HOTFUN
HOTFUN's Avatar
My 86 K30 454 I just replaced the 4 port vacuum port switch on the thermostat housing and Oreilly's had a BWD replacement in stock for $28. It is gray colored. Don't have the part number on hand but they found it right off. The GM switch was discontinued.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 10-19-2014, 10:32 AM   #6
Mv7fd
No one has a 2 port purple top in stock. Can I just jb weld it back together would it still work right?
Old 10-19-2014, 11:43 AM   #7
rich weyand
https://www.google.com/search?q=gm+t...ed=0CAcQ_AUoAg
Rich Weyand
1978 K10 RCSB DD.
Old 10-19-2014, 12:51 PM   #8
Mv7fd
Yeah that's what I'm looking for called all over no one has them. I'm going to jb weld it and hope it holds until I find one
Old 10-19-2014, 01:00 PM   #9
rich weyand
Is this not in stock?
http://www.ww.auto-parts-online.com/...cks-pvs45.html
Rich Weyand
1978 K10 RCSB DD.
Old 10-19-2014, 03:14 PM   #10
Mv7fd
No
Old 10-19-2014, 03:57 PM   #11
Axle
Axle's Avatar
Bunch available on rockauto if you are not particular to having a purple one.
Blue, Black, Natural, Orange, Green, red. Under electrical & relay->ported vacuum switch.
Alex.
Axle is offline   Reply With Quote
Old 10-19-2014, 04:30 PM   #12
Mv7fd
What is the color difference though. They didn't just make there with a bunch of different colors because they look cool
Old 10-19-2014, 09:18 PM   #13
Mv7fd
Looks like if I go with the edelbrock 2101 intake manifold that part won't be needed neither will the egr and it'll still work with the quadrajet
Old 10-21-2014, 06:58 PM   #14
Axle
Axle's Avatar
Color = opening (or closing) temperature. So, you need to know what you are controlling and what those others controlled. ie: an EFE temp switch won't be any good in place of the EGR temp switch.
Alex.
Old 10-21-2014, 10:10 PM   #15
Mv7fd
I believe it's an egr temp switch
Old 10-22-2014, 10:07 PM   #16
C10wip
C10wip's Avatar
Not sure, but I may have been looking for the same thing and 83GMCK2500 posted a bunch of useful GM part numbers which I used to cross reference. My truck is a 80 C-10, 4.1 .
http://67-72chevytrucks.com/vboard/s...d.php?t=607323
You might also try eBay using the part number.
1980 C10 Custom Deluxe, 250 L6, 3 in the tree.
C10wip is offline   Reply With Quote
