Old 10-21-2014, 07:55 PM   #1
Saave1960
1960 to 83 front suspension swap.
Just bought a 1983 rolling chassie w/power steering. My idea is to put airbags in the 1983 front suspension and swap into my 1960. I also want to use the 83 power steering and rear diff.
Just for reference my 60 has a 6cyl 235 with a T5 tranny and air bags already in the rear. I am going to pull engine and install the power steering and ac compressor while doing suspension swap.
I'm a young guy and would like to hear some seasoned and some not advice.
Saave1960 is offline   Reply With Quote
Old 10-21-2014, 08:02 PM   #2
Saave1960
Re: 1960 to 83 front suspension swap.
Frame
Old 10-21-2014, 09:17 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
If you're swapping the 83 suspension on the 1960 frame, the following thread will probably be helpful:
http://67-72chevytrucks.com/vboard/s...ont+suspension
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-21-2014, 10:20 PM   #4
Saave1960
I have read and reread your post sir, great write up.
Old 10-22-2014, 01:18 AM   #5
Captainfab
60-66 Nut
If you are keeping the 235, you will have to transfer the front engine mount from the '60 crossmember to the '83 crossmember. I haven't done so, but it may need to be modified.
Old 10-23-2014, 12:57 AM   #6
Saave1960
I am keeping the 235, have you seen anyone do the swap with one? On another note, what kind of deal you can you do on both PB & PS kits (don't need powder coating)?
Old 10-23-2014, 01:26 AM   #7
Captainfab
60-66 Nut
No I have not seen a 235 used with a suspension swap.
I'll send you a PM regarding PS and PB.
Old 10-23-2014, 10:38 AM   #8
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
if I remember right the 235 should already be tapped for side mounts, I will check the one in my 61 today ( I think all the cars used side mounts by then) ,if that is the case, then all you should have to do is source a set of mounts , (or fab 'em up) from a 73-87 6 cylinder.
hope more people weigh in on this idea, just guess work on my part....
Old 10-23-2014, 10:37 PM   #9
jonzcustomshop
1961 crewcab
my 61 235 is tapped for side mounts
Old 10-25-2014, 12:03 PM   #10
Saave1960
Sure does have side mounts.
Old 10-25-2014, 06:43 PM   #11
chopper john
chopper john's Avatar
When i did my swap , after intalling the crossmember i put a small piece of two by four laying in between the crossmember and oil pan . Then installed the horseshoe mount with the frame mount section and just drilled it in to the frame.... Now to tighten the nut and bolts that you install i can drill an accesses hole through the botton for your wrench or you can put your hand through the side of the crossmember
chopper john is offline   Reply With Quote
Old 10-25-2014, 07:43 PM   #12
Saave1960
Did you attempt to level the engine in any way or use a reference point?
Old 10-27-2014, 08:21 PM   #13
chopper john
i did put a leveler on top of the valvecover before and when i put the the two by four to measure it was just about exact
