Old 10-23-2014, 08:44 PM   #1
jastewart25
Leak Transmission/Transfer Case Identification Help
Hi All,
Bought a 1985 Chevy K10 swb with 350 (supposedly) Can't really trust the previous owner I am finding out.
I am not at all mechanical and know very little about cars/trucks but I am learning!
I could use your help identifying which transfer case and transmission I have. I took a few photos that I hope help.
I'm also worried about the putty on the end of transfer case going to drive shaft. Why is there putty there/should I be concerned? I could see fluid dripping from it after use.
On the orange cover it says CFD 207. Near it it has 140373 77
The 77 has larger numbers than the rest.
The other letters I see shown in photos are AE followed by 6 numbers I can't see.
Thank you!!!
jastewart25 is offline   Reply With Quote
Old 10-23-2014, 09:27 PM   #2
russgt
russgt's Avatar
Re: Leak Transmission/Transfer Case Identification Help
The transfer case is a NP205 with a slip yoke and it looks like it has a turbo 350 trans in front of it. I would guess that the they are out of a 1980 model truck and are not original to your truck.
The putty should not be there and is most likely covering up a crack. The tail shaft is a replaceable part, so it can be fixed.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 10-23-2014, 10:20 PM   #3
jastewart25
THANK YOU!!!
i will try to search for a tail shaft replacement. any clue as to where a good place to get them from would be?
thanks again!
1985 chevy k10, transfer case, transmission
