Old 10-26-2014, 04:41 PM   #1
1972BlueC20
1972BlueC20's Avatar
Can I just rip out my AC System?
I got my truck all torn apart today. I was doing a heater core replacement. Got the heater box out and got the new heater core secured in place inside the box. I also went ahead and changed out the blower motor and metal fan blade. I'm also replacing the heater blower speed resistor while I'm inside there too. I also have all the gaskets for the heater box.
I was having some troubles with air coming into the vents when driving down the road and some of you guys suggested that the blend door was stuck open or in need of a gasket to seal it off when closed. I also was having trouble with my heater control levers. Seemed they were binding a bit and were hard to move from left to right. Well now that I got everything apart I see that the lever for the door in the floor box area was tweaked and bent causing it not to close all the way hence the air coming through the vents and the binding of the controls. I tweaked everything back and it's now working smoothly. With the heater control out of the dash the levers seem to move smoothly too and the cables are all going back and forth with the lever movement. So I guess if I hook everything back up correctly it will work properly now?? Is there anything else I should check or replace while I'm inside the dash?
So I think I have all that sorted out for the most part. I also noticed that my heater air ducts were all dry rotted and torn apart or had come off where they were supposed to be hooked to. So I'm ordering new ducts and will secure everything with hose clamps to the heater box inlets and the dash vents.
Any suggestions and or help is greatly appreciated!!!
My main reason for this long post is to ask you guys a question.
I have an old dealer installed Clardy hang on aftermarket AC System in my truck. It's never blown cold since I bought it and recently it stopped blowing all together. I found out today why it stopped blowing and that's because the fuse for the blower had blown out. There may be another issue that caused the fuse to blow, so I don't know if changing the fuse is a long term fix. When the AC was working, it never blew cold. I recently got a quote to convert it to R134a for $800, and that's without a new compressor!! I passed on that deal. My compressor is an old York compressor and its making some noise, so it probably needs replacing too.
My question is can I just unhook everything and just rip the AC system out? I think the system is pretty much empty anyways of freon. I know technically you're not supposed to just bust the hoses off, but if you don't tell I won't LOL.....is there anything to be mindful of if I do that??
I may eventually install a vintage air system later down the road or just go with no AC.
Oh and I forgot to mention too, nobody in my area will mess with R12 anymore. So unless I can do the work myself, converting to R134a is the only way if I want AC. My initial idea, before the blower stopped was to just fix any leaks and recharge with R12. Nobody around here that I KNOW OF will do that for me.
Here are some pics of what I'm dealing with :
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 10-26-2014, 04:41 PM   #2
1972BlueC20
Re: Can I just rip out my AC System?
a few more pics :
Old 10-26-2014, 05:18 PM   #3
wreckedchevy
wreckedchevy's Avatar
I ordered the plastic replacement ducts instead of the original style just cause I thought the would be more forgiving and age resistant but they don't fit worth a darn they are very loose and just fall off. I couldn't find a way to get hose clamps on them but used black zip ties and worked perfect. One more note if your defrost vents are the originals they break a lot easier than I thought both of mine completely exploded in my hands taking them out.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 10-26-2014, 08:21 PM   #4
57larry
could junk it all and go with Vintage Air
57larry is offline   Reply With Quote
Old 10-26-2014, 08:27 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
While you've got it apart, lube the cables well so that they continue to slide easily. I usually use a lock lube called "Lock Ease" but it's graphite and can get messy. I had my cables off when I did the heater core(non A/C) and left the cables laying in a drain pan of oil, then let them drain for a day before reinstalling.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-26-2014, 08:37 PM   #6
1972BlueC20
Thanks guys!
I will lube the cables too, good idea!
So what will happen if I bust the hoses off the compressor? Is it a lot of pressure? Can it cause injury? That's really my main concern....once the pressure is released It's just a matter or pulling all the components out.
Also the A/C hoses go to a trans cooler looking thing in front of the radiator. Do I just remove that whole thing too?
I will need to plug the holes where the ac hoses go through the firewall near the heater box. Do they sell any pre-made rubber plugs? I can't seem to find them if so.
Old 10-26-2014, 08:42 PM   #7
see ten
WTB this ad
see ten's Avatar
crack open a line... if there's any pressure on it... you'll hear it. Walk away... it'll gas out in a few minutes. Remove anything associated with that ac system and ditch it.
see ten is offline   Reply With Quote
Old 10-26-2014, 08:55 PM   #8
Blown06
Blown06's Avatar
Pull the plastic caps at the suction and or discharge of your compressor, they should just screw off. There should be a shraeder (sp?) valve eye hind them. Put on a pair of gloves and use a small screwdriver to relieve the system pressure. Just like letting air out of a tire. Then you should be all set for cutting the hoses.
The thing in the front is the condenser and can be removed. If you plan in the future to go with a vintage air or other system, all that stuff will get replaced anyway.
Hard for me to tell on your pics but you could also remove the belt to the compressor. If something else is also getting driven by the belt then just leave it on. The clutch will keep the compressor from engaging. Technically you shouldn't vent the system, but the law states that you have to recover a percentage of it. If there is zero pressure, it's hard to recover a percentage of zero. Wink wink!
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 10-26-2014, 08:46 PM   #9
Ozzy2013
Ozzy2013's Avatar
You can bleed off the system at the schrader valve thats where the fill is for the system.The conversion to r134 isnt hard at all just evacuate the system and refill with oil and coolant .I would replace the compressor you can buy used ones at the junk yard reasonable .Texas can get hot!
Ozzy2013 is offline   Reply With Quote
Old 10-26-2014, 08:50 PM   #10
1972BlueC20
Sweet, so let's assume I wanted to replace the compressor and convert to R134a.
What tools would I need to flush and fill the system?
New hoses? Condenser? Compressor? Oil? Freon? Fittings?
I know really nothing about AC systems, but I've been told with my skill level I can do it.
Old 10-26-2014, 08:52 PM   #11
joey8383
joey8383's Avatar
Be careful dumping any refrigerant. EPA fine is $$$$. And liquid refrigerant can cause severe burns.
That compressor will sell on EBAY. Back in my 4 wheel drive days, we would use them old York compressors for onboard air. They're tough
joey8383 is offline   Reply With Quote
Old 10-26-2014, 08:57 PM   #12
joey8383
joey8383's Avatar
To convert, dump your old oil from compressor in to a measuring cup. Or dump it and look up the factory oil charge. Fill with proper amount of PAG oil. Leak check with dry nitrogen. Dump nitrogen out. Vacuum with a vacuum pump down to 500 microns. Weigh in charge of R134a (roughly 2 lbs +/- .75 lb?)
Need:
Gauges
vacuum pump
micron gauge (or chance it and just run the vac pump a couple hours to be sure)
refrigerant and oil.
R134a condensers are usually larger than R12 condensers. I have converted a bazillion R12 cars and some will run higher than normal head pressure due to fact that the condensers are smaller. You could replace the condenser or make sure fan or electric fan is moving plenty plenty plenty of air. Especially at idle. Good luck
Old 10-26-2014, 09:07 PM   #13
57taskforce
All about them K’s
57taskforce's Avatar
I've converted a few r-12 systems over. It's just a couple 134a fittings, vacuum, oil charge,134a charge, cold air. Be advised it won't run as efficiently(ie won't be as cold) as it would be with r12. It will keep you cool enough tho. For the vacuum and recharge any shop should be able to that for you for FAR less than 800. No sure what the $800 quote entailed but seems very steep to me.(for a few hundred more you could get vintage air)
Tyler
Old 10-27-2014, 12:39 AM   #14
no1udknow
no1udknow's Avatar
I always hear people say that r134 is not as efficient as r12, do you think that possibly there is a need for a greater restriction/orifice before the condenser? I used to do some home A/C retro fits and I know if wevever swapped for 134a we had to change the orifice at the condensor. It looked like a tiny brass carburetor jet.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 10-27-2014, 12:34 AM   #15
no1udknow
no1udknow's Avatar
Ummm, quick tip about refrigerant. If you decide to "crack open a line" or "bleed it out at the shrader valve" ease do it ouside and not in your shop. First off, it is a huge fine if someone sees you doing it, but from a safety standpoint, r12 and r134 displace oxygen. Every single molecule of refrigerant gathers 10 molecules of oxygen to it and becomes heavy and falls to the ground. This in turn displaces a significant amount of oxygen and can cause you to pass out if it is not in an open ventilated area. Safety first that's all I'm saying.
Built not bought!
Old 10-27-2014, 09:45 AM   #16
Katrina/10
Katrina/10's Avatar
That old AC system you have looks good, I'd try to fix it. May just need a charge, in Texas I'm sure you will want some cool air in the summer.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 10-27-2014, 10:56 AM   #17
engineer_gregh
engineer_gregh's Avatar
I have the exact same set up on my 71. Installed by a dealer in Birmingham AL in 1979 at a cost of $440. I've removed mine to replace all the rotten hoses and get new condenser. I'm also looking to go with crimped hose connections as I'm not sure the barbed connections will hold up to the increased pressure of the R134a. Mine worked ok till one of the lines split under pressure last year.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 10-27-2014, 11:29 AM   #18
1972BlueC20
You just brought up a good point. I think I'm going to try and keep the hang on AC system, but I want to replace the dryer and the hoses with the new crimped style hoses and convert to R134a.
How and where do I get the right length hoses with the newer crimped style ends like the newer cars?
Old 10-27-2014, 08:26 PM   #19
mechanicalman
OK if the old compressor was making noise, it's bad. You want new compressor, crimped style hoses, R134A fittings, and a new drier. This kit comes with ALMOST everything you need, you fit up the lines, cut them and mark them for alignment then take them to an a/c shop and have them "swedged". Everything with a rubber o-ring seal will need to come off and get a new seal.
IMPORTANT: what kind of controls does your old unit have, expansion valve? Can you take pictures of everything outside of both the inlet and outlet sides of the evaporator core (knee-knocker unit)? This system comes with a "pressure switch" that might be for a cycling system but you would have to ask the seller.
You see, the parts that control the pressures will have to be 134A compatible. Might be a simple orfice tube replacement, might end up being something more complicated/expensive.
Oh, and detailed pictures of the condenser. There is a certain type of condenser that is not compatible with 134A so we need to eliminate that.
http://www.ebay.com/itm/SANDEN-STYLE...b240d8&vxp=mtr
DON'T GIVE UP until you know IF it can be done and HOW MUCH it would cost to make the old system work.
You might not want to spend that much money then find out the evaporator core leaks. If the evaporator core is dry and free of oil, that's a good sign. Always use a back-up wrench and never put any strain on the evaporator core or condenser core.
mechanicalman is offline   Reply With Quote
Old 10-27-2014, 09:15 PM   #20
1972BlueC20
Here are more pics as requested :
Old 10-27-2014, 09:17 PM   #21
1972BlueC20
More :
Old 10-27-2014, 11:33 AM   #22
engineer_gregh
I'm still researching that myself. I'm going to mock it up with heater hoses (cheap to do) to get the right length then try some local shops that do hydraulic hoses. I like the look of the hang down air and I don't want to give up my glove box with the vintage air kit.
Greg Smyrna TN
Old 10-27-2014, 11:40 AM   #23
1972BlueC20
Cool, if you figure anything out please let me know and I'll do the same.
I might just hook everything back up and see if the system will hold a vacuum for now. If it does, then i might just retro fit to r134a and see if it all holds and works with the existing hoses. I'm watching videos now on AC work. LOL. Gotta love YouTube!!!
I just gotta figure out the procedure for flushing the system and getting the new oils inside.
I've learned now how to check for leaks, how to put a vacuum on the system and how to charge.
I'll need to go buy a vacuum pump, a gauge set to start. Making a list of what all I will need.
Any comments or additions would be greatly appreciated.
Old 10-27-2014, 11:37 AM   #24
57taskforce
All about them K’s
Parker supplies the hoses for vintage air, (or at least that's what came in the kit for my 57) they are quality crimp fittings and quality hoses as far as I can tell) I'm pretty sure any local hydraulic or even residential ac companies can get ahold of what you need
Tyler
Old 10-27-2014, 12:02 PM   #25
no1udknow
no1udknow's Avatar
For the price of vacuum pump, gauges and fittings, you might be better taking it to someone or maybe finding a mobile guy. I know here in Cali there are guys that will come out just to recover the refrigrant. They could probably vacuum test it also.
Built not bought!
