Old 10-26-2014, 10:03 PM   #1
ripper70
ripper70's Avatar
Wiring Pics
Would anyone happen to have pictures of there Maxi-Fuse location for the painless wiring harness? Also how about underhood pics of finished wiring? Im starting my wiring and havent had much luck with search on pictures. Thanks in advance.
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 10-26-2014, 11:14 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Wiring Pics
Here is the painless manual for non column keyed ignitions. Page 7 shows the maxi fuse wired off the starter large terminal in the alternator and the cab power wires.
http://www.painlessperformance.com/Manuals/10102.pdf
The factory uses fusible links and puts one between the battery positive and the
junction stud on the right fender as shown in the diagram below at the top.
The circled items are the fuses for the battery gauge wires and the SHUNT wire is the battery connection wire with the alternator to provide a path for voltage to the truck circuits with the engine off and the key on. It is also the charging wire for the alternator to charge the battery.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-27-2014, 01:04 PM   #3
BigBlack
BigBlack's Avatar
Re: Wiring Pics
I put mine on the pass firewall/trans tunnel!!! The maxi fuse can be placed where ever you want to put it, if im understanding your question right!!!
Projects --
72 Chevy k10 4x4 lwb 350/350
69 Chevy c10/CST 2x4 lwb BB 396
BigBlack is offline   Reply With Quote
Old 10-27-2014, 09:08 PM   #4
ripper70
ripper70's Avatar
Re: Wiring Pics
Thanks Vette for the info but was looking for pictures of maxi-fuse locations and underhood pics of finished wiring jobs if anyone had any.
Thanks big black, that sounds like a good spot.
Anyone else?
1970 K20
1967 Blown Stepside
1989 Jeep Cherokee
1995 S-10
