Old 10-27-2014, 11:44 PM   #1
newstedcomeback
newstedcomeback's Avatar
1971 C/10 to K/20 Conversion
I bought this truck back in 2007 for $750, Its a 71 2wd truck with coil springs on all corners and Im PROUD to say that its a long bed.I have taken it from this, to that, Lowered to stock to lowered, 20' Irocs to 15' black steelies, th-350 to 700r4 to Super T10 and back to 700r4 and I keep finding new directions to go with it. Well I finally decided that I want it to be a HEAVY Half ton 4x4. I want a 4 inch lift with 35's 8 lug dana 44 front and a 14 bolt in the rear. I want 4.10 gears for towing and climbing trails.
It currently has a vortec 383 that I built with about 1500 miles on it. I built a 700r4 for it about 3 years back, So my powertrain is pretty solid right now. I have been collecting parts for about a month now and I am about ready to start tearing apart the truck. I found a rolling 1971 4x4 frame on craigslist 2 weeks ago. It is the perfect start for my project because I can weld but I am no frame fabricator. I didnt want to have to deal with all the fun of converting a frame with coils on all 4 corners to leaf springs, so I took the easy route. Pics will follow soon. please subscribe and encourage me to work on this as much as possible. I need motivation. lol
newstedcomeback is offline   Reply With Quote
Old 10-27-2014, 11:53 PM   #2
newstedcomeback
Re: 1971 C/10 to K/20 Conversion
Aww man. Can you see how excited my girlfriend is about getting up at 6am and towing a flatbed 200 miles round trip. "We drove all this way... FOR THIS!!??!!?" Priceless.
Old 10-28-2014, 12:05 AM   #3
newstedcomeback
My 2011 canyon 4x4 with the trailer my buddy let me use
Old 10-28-2014, 12:03 AM   #4
andrewmp6
I would skip the dana 44 for a dana 60.
Old 10-28-2014, 12:08 AM   #5
newstedcomeback
Dana 60's are soooo expensive! And impossible to find in my area. I have 2 front dana 44's so I figure I could bring an extra set of axle shafts if I break anything. I just wanna have a little off road fun. I don't plan on going any bigger than 35's and I'm gonna keep the front diff open for now. I don't wanna rock crawl or anything. Just dirt trails and maybe a little mud. But no swimming. Haha
Old 10-28-2014, 12:16 AM   #6
newstedcomeback
But I know a dana 60 would be the best choice. I only found one at the wrecking yard and it was super rusty halfway sunk in mud, dually setup and the man wanted $750 for it. I think a 44 will be good for now. It'll get me rolling.
Old 10-28-2014, 12:18 AM   #7
newstedcomeback
More recent pic
Last edited by newstedcomeback; 10-28-2014 at 12:20 AM. Reason: Forgot to add picture
Old 10-28-2014, 12:32 AM   #8
newstedcomeback
The truck has a solid build 700r4 that was from a 89 suburban 4x4 and I converted it to a 2wd trans during the rebuild, it has the beast sun shell, corvette servo and a shift kit. Luckily I kept the output shaft, the 208 transfer case and front driveshaft. So I have a good start on the parts for the conversion. I am curious about the 208 case on the stock 205 crossmember.. Will it fit? Do I need the tall mount adapter ? I know the np205 is a much better case but I don't have one and I know it is difficult mounting up to a 700r4. I can always upgrade later on. But for now I'd like to make what I have work.
Old 10-28-2014, 12:54 AM   #9
newstedcomeback
My engine. Vortec 383. Eagle crank and rods, speed pro dish pistons. Edelbrock performer rpm 400 smallblock cam. Vortec heads were new from summit, I machined for screw in studs, roller rockers, air gap intake and a Holley 670 street avenger with a street scoop with functioning butterflies.
Old 10-28-2014, 12:57 AM   #10
newstedcomeback
More
Old 10-28-2014, 01:15 AM   #11
newstedcomeback
Got some 33 inch BFG on 8 lug 16.5 rims. All 4 for$100 about 1/4 tread left. Great as rollers for the project. I installed 8 lug hubs from
A 10 bolt I found at the junk yard. Everything bolted right up.
Old 10-28-2014, 02:33 AM   #12
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-28-2014, 06:12 AM   #13
andrewmp6
Some guys have used a dodge dana 60 from the 93 and older trucks.All you need is this http://offroaddesign.com/catalog/Dod...apBushings.htm and rest should be easy.
Old 10-28-2014, 12:35 PM   #14
newstedcomeback
Thanks for the info. It's good to know that the option is there, it's just so much $ to spend. I'd rather put that $ other places for the time being.
1971 Chevy K30 / 454 / TH400 / NP205 / Dana 60/14 bolt FF on BFG Baja 37's - Build Thread : http://67-72chevytrucks.com/vboard/s...d.php?t=647877
2018 Silverado 1500 5.3 LTZ Z71 - daily driver
2019 Tahoe Z71 5.3 - (Wifes daily driver)
Old 10-29-2014, 02:21 AM   #15
andrewmp6
Yeah its good to have other options,Really only thing you should add is a steering box brace and its 130 bucks from offroad design.
Old 10-29-2014, 04:38 PM   #16
k5xjfiles
Junior Member
k5xjfiles's Avatar
That Dana 44 will be fine if you don't go nuts....especially since it will be open.
72 K5/10/20 Hybrid 350, 465/205 44/14 bolt 35s, Detroit locker
89 XJ Pioneer, 4.5" 32s.
98 ZJ DD.
Parting..87-01 Cherokees
I bore throttle bodies-PM me for details!
k5xjfiles is offline   Reply With Quote
Old 10-29-2014, 04:58 PM   #17
newstedcomeback
Yea the dana 44 is gonna stay until I break it. Here's a pic of the 4 inch lift on the front.
Old 10-30-2014, 08:03 PM   #18
WhiteWhale
WhiteWhale's Avatar
why dont you leave the 700R as it is and run a divorced NP205?
WhiteWhale is offline   Reply With Quote
Old 10-30-2014, 10:45 PM   #19
newstedcomeback
Thats an idea... But then I would have to make a crossmember for it and deal with the super long linkage to put a stick in the cab. I dont think i want to go that route.
Old 10-31-2014, 02:14 AM   #20
andrewmp6
They do make cable shifters and you could even twin stick a divorced case also.
Old 11-06-2014, 05:05 PM   #21
newstedcomeback
Thumbs up Re: 1971 C/10 to K/20 Conversion
Today I decided that I'm gonna go with a steering angle correction arm from ORD. This makes the drag link more level and at less of an angle with a 4" lift. Should help prevent bump steer. I'm gonna go with this for now and maybe someday later on a can convert to crossover steering.
http://offroaddesign.com/catalog/steeringcorrection.htm
I have read that taking the stock steering arm off the knuckle is almost impossible. And I would have to agree. However I used my portable band saw and pie cut sections I used LOTS of penetrating oil and then used a chisel and big hammer to rotate the cone washers enough times to keep slicing chunks out of them. I did happen to cut into 2 of the studs. But I double nutted the studs and backed them out with an impact gun.
Old 11-07-2014, 02:31 AM   #22
72 Copper C-10
72 Copper C-10's Avatar
you should beable to make the 208 fit with the 205 crossmember, but you have to have the older style 208 mount and adapter. You will probably have to modify the floor to fit the 208. I had to do the same thing with my 241. As far as strength I think it's plenty strong, my friend has a mud truck with a Big block pumping out 600 plus horsepower and it hasn't had and issue. The Low range in the 208 is so much nicer than the 205
72 Copper C-10 is offline   Reply With Quote
Old 11-07-2014, 08:56 PM   #23
newstedcomeback
Today I moved the Dana 44 outside and cleaned it. I used degreaser in a spray bottle, a big screwdriver, and a wire brush. I Pressure washed it after i scrubbed everything loose. It came out pretty good. I plan on changing all the seals and painting it soon. at least now I can touch it without instantly getting my hands filthy.
Old 11-08-2014, 05:18 PM   #24
70stroker
70stroker's Avatar
Looks good, im in middle of doin the exact same thing right now.
70stroker is offline   Reply With Quote
Old 11-16-2014, 01:47 AM   #25
newstedcomeback
I picked up a front sway bar of a later model 3/4 ton truck. I also picked up a 700r4 4x4 output shaft and a tall adapter for a 700r4 to a NP208. The 208 I have sat outside for a while and got some dirt inside the case. So I plan on doing a full rebuild..
14 bolt, 1971 71, 383, 4x4 conversion, 8 lug
