1972 chevy k20 front brake hose info?
I'm am looking for answers!!! I am trying to find out
The thread size of the fittings on my front brake hoses. I have Found out that the side that bolts to the caliper is a 7/20 banjo bolt? Is that correct? However I can't find what type and size of the fitting that is on the frame side. My truck is a 1972 chevy k20. I am wanting to know this info So I can make my own braided lines. I have the braided line, but need to order The correct fittings. Any and all help would be awesome. Thanks Jeremy |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: 1972 chevy k20 front brake hose info?
My only suggestion (not much help, I know) is buy or borrow one from a parts store. I bought new ones at NAPA recently, perfect fit and not too expensive IIRC. At least you'll be able to see exactly what size/type fitting is used, as well as the threads.
Edit: checked online, found p/n UP 36761 with pics and a description including thread size. http://www.napaonline.com/Catalog/Ca...761_0342274941
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 10-29-2014 at 04:16 PM. |
Stocker I tried to find some info on that part number
You sent, no luck. Thanks for the help though. |
20' Daredevil (Ret)
It's a NAPA part number -- did you check with a NAPA store? Were you able to click on the link I posted? Here's what the link has about the threads on each end of the hose:
Hose End Type 1 : Banjo - 0.44 Hose End Type 2 : Male/female - 5/8"-18 Ext & 3/8"-24 Int
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 11-01-2014 at 11:37 AM. |
I don't recall the thread size on the frame end of my 72 K20 but i bought new hoses from Offroad Designs for my truck after i installed my 4" lift. This is the part number they sent me, if your still searching maybe a call to them would help id the thread size?
(GU30071) BRAKE LINES - VEHICLE KIT (‘73-‘78.5 -- 4-6” lift) (2 fronts, 1 rear) http://offroaddesign.com/catalog/braidedbrakelines.htm
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
