![]() Join Date: Feb 2010
Ltb
Steering column and wheel
high transmission hump (needed for lsx swap) located in Charlotte NC willing to travel a little
1980c-10 mybaby |
![]() Join Date: May 2011
Re: Ltb
I have a non tilt column I just pulled out and high hump with washers weld on the top holes can get pictures to night if interest. Might be late trick or treat is tonight.
Re: Ltb
The holes in the cover were egged out so I welded washers on years ago not rusty except were the paint burned off should clean up fine. There is two holes from a fire extinguisher mounted to it also 50 plus shipping. The green column was out of my original blazer and it worked fine the day I pulled it the four way flasher broke off in storage I can send one along if you would want that one. The brown one that is already out I drove the blazer around the block and then pulled it apart so I really do not know anything about it. The fiber optic is broken so I could send one along if you wanted that one. The last one is still in the blazer but could pull it but again the motor was blown so I never drove it so don't know anything about it. The knob on the blinker lever is missing so i could send one along if you wanted this one. I have two steering wheels the one on the brown one and the new black one still in the blazer. 60 dollars plus shipping for any of the columns. I would have to look at the steering wheels again to give you a price could also get better pictures if needed. Let me know if interested in anything
Re: Ltb
I see from the pictures the selector bracket is also broke on the brown one.
