Old 10-30-2014, 12:15 PM   #1
dunce79
Question 1959 Short Fleetside bed plank dimensions
Thinking about having friend of mine who is a woodworking guy come up with something for my 59 Fleetside bed instead of buying one of the kits that are available. Has anyone seen any specs/dimensions on what size ect each plank should be?
dunce79 is offline   Reply With Quote
Old 10-30-2014, 12:27 PM   #2
Rude Dude
Rude Dude's Avatar
Re: 1959 Short Fleetside bed plank dimensions
http://www.chevytrucks.org/tech/bedwood.htm
Rude Dude is offline   Reply With Quote
Old 10-30-2014, 02:15 PM   #3
dunce79
Thx. saw that while searching and just thought I'd try to back it up with other info.
Old 10-31-2014, 07:48 PM   #4
OrrieG
OrrieG's Avatar
When you make them, cut perpendicular notches from the grooves the rails sit in to the sides about every 12 inches. Without them any moisture has to run all the way to the front and back sills to drain, or sits and rots the wood.
Old 11-01-2014, 11:41 AM   #5
_Ogre
_Ogre's Avatar
and... since your not restoring the truck you can make them any width or material
truk has trex plastic decking from homedepot, they are all the same width and no finishing or protection required
stock bed strips were painted black and raised above the bed wood to protect the wood from a shovel
if you paint your bed strips and don't want the paint beat off them, lower the strips a bit
shop air compressor timer
Old 11-01-2014, 02:10 PM   #6
OrrieG
OrrieG's Avatar
You forgot to mention you have to re-drill the cross sills....
Old 12-08-2014, 01:37 AM   #7
1966chevy
1966chevy's Avatar
Great idea! I might look into that for my fleetside bed.
1966chevy is offline   Reply With Quote
Old 11-02-2014, 06:07 AM   #8
Old Crow
Old Crow's Avatar
For my old shop truck, I just bought a 4x8 sheet of 3/4" treated plywood. Measured the distance between the bolt holes in the cross sills and ripped the plywood accordingly. After all the cuts were made and the holes drilled for the bed sides and mounting bolts, I coated the pieces with Thompson's water seal. I didn't even bother to route the grooves for the rails, just bolted them on top.
Figured I didn't want to spend big bucks for something I was going to use to haul engines, tranny's and firewood. Sure enough, the first time I put a motor in the back of the truck, it fell over and dumped about a quart of old, nasty oil on the bed.
Aside from the new rails and bolts, I've got about $50 in my bed. Still got about 1/2 gallon of Thompson's, so the next replacement will be about $38.
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
Old 12-08-2014, 01:40 AM   #9
1966chevy
1966chevy's Avatar
1958-1966 Truck Fleetside Tailgate, Ultimate hinge Trunnion (2 Piece Set) made of Stainless Steel and Delrin.
These are replacement hinge trunnion parts to upgrade your chevy fleetside truck.
These are perfect for the truck restorer!
These are Very quite while opening and closing the tailgate.
You have to reused your original Trunnion hinge plate/bracket as seen in the pictures. Just remove the bolt with lock washer, replace with these stainless steel hinge trunnions and bolt back on your truck.
I recommend power coating or chrome your Trunnion hinge plate before installing these back on it. To prevent further rusting.
See my attached link if your interested in purchasing"
http://www.ebay.com/itm/171632939274...9#ht_517wt_974
I also offer a cheaper version, Made of all Stainless steel on this listing:
http://www.ebay.com/itm/171632938635...9#ht_498wt_974
I also in the works on building 67-72 trunnion hinges.
Website is: http://tdtrunniondesign.com
My project, http://67-72chevytrucks.com/vboard/s...d.php?t=552896
66 chevy truck Fleetside LS1
67 Camaro Convertible 327
