Old 10-30-2014, 09:54 PM   #1
scott657
scott657's Avatar
Ignition resistance
I have a 63 C10 230 stovebolt. Voltage to coil 13 while running coil resistance 1.5 ohms Voltage from coil 12 to Points. Is this to much voltage to the coil?
Wiring diagram shows a white /orange wire from ign to R terminal on the solenoid changing to green and continuing to the coil. (In actuality the wire on my truck is not W/O)
My questions is is the w/o wire supposed to be a resistance wire? Do I need a lower voltage to the coil? I have no problem adding a ballast resistor, if necessary.
scott657 is offline   Reply With Quote
Old 10-30-2014, 10:11 PM   #2
Irishbleueyes
Re: Ignition resistance
You need the resistor, should be around 8 volts. Keeps the points from burning out. Pretty much get it anywhere
http://www.partsgeek.com/gbproducts/...FU9efgodWT0AsQ
Irishbleueyes is offline   Reply With Quote
Old 10-30-2014, 10:14 PM   #3
scott657
scott657's Avatar
thanks for the fast response!
Old 10-31-2014, 10:22 PM   #4
scott657
scott657's Avatar
I put a resistor in ran the ignition wire to one side of the ballast, coil wire to the other side, then took a separate wire from "R" directly to coil. Im getting right at 9 volts to the coil thru the resistor, problem solved
And thank you
