Old 11-02-2014, 01:35 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up Seats and console
Bought the seats a month ago at the local LQ yard for $60.00. Got the electronics working on both of them except for the drivers side heater. I have ordered new covers for them both and plan on putting aftermarket heaters in them so I will have both bottom and backs heated instead of just bottoms.
I bought the console off a local member here and will have it refurbed to new again I hope and will install them all into the 71 when done.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-02-2014, 01:49 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Seats and console
Here is the bad of it. The console I hope can be fixed with some minor work. These are the only problems I can find wrong with it. I'll replace the cup holders with the stainless ones if I can find them with new trim also I hope.
The inside frame is cracked up front and there is a small hole on the side right at the trim. Shouldn't take much to fix I hope.
Old 11-02-2014, 05:59 PM   #3
RUN GMC
RUN GMC's Avatar
Cant wait to see this Andy....I too like the older console with newer seats......I might install mine with 2000 trans am seats without the headrest.......the main thing wrong with my truck this year's Power Tour was the bench seat became uncomfortable and no cup holder.....plus a console would me clean up the cab quickly with a place to tuck stuff away..........
RUN GMC is offline   Reply With Quote
Old 11-02-2014, 07:28 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Seats and console
I like my 89 Chevy bench seat but just ready for a change. I have cup holders also to in the S-10 shifter I installed.
Old 11-03-2014, 01:06 PM   #5
RUN GMC
RUN GMC's Avatar
Would like modern seats in mine but with classis console........my present set up.........
Old 11-03-2014, 02:05 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: Seats and console
Can you not buy the slip out cup holder for the ashtray mod?
Old 11-03-2014, 11:43 PM   #7
RUN GMC
RUN GMC's Avatar
Yes I can/could and might do that if I dont get around to interior redo before 2015 Power Tour(where ever we may be going).....but that option may not make my lower back and butt happy while long hauling in 2015
Old 11-04-2014, 12:51 AM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: Seats and console
Understand!
Old 11-03-2014, 02:07 PM   #9
Hugh Mongus
How wide are the classic consoles?
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 11-03-2014, 04:49 PM   #10
Andy4639
Old member
Andy4639's Avatar
Here is what I'm looking for. Just to give a idea. Once I have the heaters and new covers installed I will start placing everything in the truck.
Going to work on the speaker boxes also and how everything is mounted.
Old 11-03-2014, 06:25 PM   #11
Tinkermc
Rhat set-up looks so nice and clean. Wonder if the headrest will work?
Tinkermc is offline   Reply With Quote
Old 11-03-2014, 08:13 PM   #12
Andy4639
Old member
Andy4639's Avatar
?????? Head rest work!
Old 11-19-2014, 12:49 AM   #13
Andy4639
Old member
Andy4639's Avatar
Drivers side is installed and wired. Seats move as they should and heaters are working. Got to drive it the rest of the week and see how everything feels and wait for my next night off which is Sunday before I start on the passenger side. I'll have to drill holes for it. The drivers side went good the brackets mounted right back in the same holes as the old seat. Seat belts everything was a easy swap.
I had plan to have the heaters turn off with the seat belt if you unbuckled it and left the switch on but the little wire pig tails in the buckle work in reverse for a buzzer I guess. They will cut off when I turn the truck off but would like to have a safety cutoff if someone forgets. Anybody know a way to do this?
Old 11-19-2014, 01:10 AM   #14
Acorn
Those will look sweet! What did those seats come out of? I have some bucket seats but I'm old and want an arm rest.
Also ( off subject) but what kind of tilt column do you have? The ones I've seen don't ever look like they tilt "up" as high as yours.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 11-19-2014, 01:39 AM   #15
Andy4639
Old member
Andy4639's Avatar
Thanks,
Seats are out of a 99 Tahoe. I bought the new covers and new heaters for them. My old buns will be warm this winter! The tilt is a factory 4 speed tilt I found in a old burned out blazer many years ago. I gave the guy $45.00 for it. Took home cleaned it up and replaced the bearings and haven't had any problems with it since.
Old 11-24-2014, 05:25 AM   #16
Andy4639
Old member
Andy4639's Avatar
Cool Re: Seats and console
Seats are both in wired and ready to ride. I worked all night on them. I have the seat belts working like I want and they cut the heaters off if the switch is left on and you unbuckle the belt.
This way I don't have to worry about weather are not it's burning the heater element up for no reason!
Oh yea I went back out and fixed the seat cover around the controller on the passenger side. It looks a lot better.
I have the console sitting on the kitchen table drying after I epoxed the crack back together. I will body fill and sand the other places sometime polish up the S/S trim piece and buy the cup holders.
Mount my 2 amps inside the thing once it's ready to install.
https://www.youtube.com/watch?v=WKgJ1P_h69Q
Old 11-24-2014, 06:27 PM   #17
RUN GMC
RUN GMC's Avatar
Now Im waiting on to see how counsel turns out just as long as it doesnt interfere with your "bangshift"-ing activities Andy after install.........lol................
Old 11-25-2014, 12:15 AM   #18
Andy4639
Old member
Andy4639's Avatar
The console was pretty bad man. I think it will be OK but it may take awhile. I have to do some body filling on it and sanding it.
Old 11-25-2014, 11:53 AM   #19
BIG ORANGE
BIG ORANGE's Avatar
Im digging the gray,, looks modern....
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 11-25-2014, 04:58 PM   #20
Andy4639
Old member
Andy4639's Avatar
Thanks, I think it looks good too. I'm picking up the new red carpet for it Friday.
Old 12-13-2014, 05:03 AM   #21
Andy4639
Old member
Andy4639's Avatar
Update on the console. I have the crack epoxied and fixed both small holes on the rim of it. Aluminum trim has been cleaned and polished. I sanded the thing down and I test fitted the cup holder in place from Frank (pickmup). Very nice. Thanks! Going to paint it Silver & Grey I think to match up to the seats. Have to decide where to mount the home link switches for the garage door opener also.
Old 12-21-2014, 06:26 PM   #22
Andy4639
Old member
Andy4639's Avatar
More done with the console and I finally got the home link mounted inside the ash tray like I wanted. I plan to hide both my amps inside the console so I mounted the fan to pull the hot air out of it from the back. I may put some kind of vent on the sides so the cooler air can be sucked in by the fan. I also cleaned up the Bowtie that goes on the top to have it painted red, What else!
I have a lot more to do to the inside of the truck. New carpet and fill the old bench seat holes up.
Check it out.
Old 11-24-2014, 10:36 PM   #23
Tinkermc
So very nice
Old 11-25-2014, 05:26 PM   #24
72bowtiestepper
Those seats look great....I'll be checkin' local craigslist for 99 Tahoe seats also !
72bowtiestepper is offline   Reply With Quote
Old 11-25-2014, 09:03 PM   #25
YBNORML
YBNORML's Avatar
Looks good!
Where did you order the covers from?
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
