11-02-2014, 05:22 PM | #1 |
No spark
Just finished installing my new 350, have ground straps connected, 12 volt to the coil but no spark. Coil, cap, rotor, plugs all new. The engine turns over very fast but I can't get spark. I went through the wiring and all seems good. Any ideas?
http://smg.photobucket.com/albums/v655/aaronhero/ |
11-02-2014, 05:24 PM | #2 |
US Army Veteran
Re: No spark
Negative battery cable to engine block?
1972 C10 Highlander - The making of a daily driver |
11-02-2014, 05:27 PM | #3 |
Re: No spark
Yep, I just don't get it! I'm pretty sure I have it timed right but even if not I should see spark
11-02-2014, 05:53 PM | #4 |
Re: No spark
The yellow wire from your starter selinoid to your coil?
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
11-02-2014, 06:01 PM | #5 |
Re: No spark
Pull cap, make sure dizzy is spinning, make sure rotor is on good. I'm sure you checked, just reaching...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
11-02-2014, 07:38 PM | #6 |
Re: No spark
hei or points and a condenser?
11-02-2014, 08:21 PM | #7 |
The Older Generation
Re: No spark
I just went through this with my '34 Ford coupe. I didn't have the coil wire all the way down into the distributor cap. Once I corrected that it fired right up. (only if you are running a points distributor) LockDoc
11-02-2014, 08:26 PM | #8 |
Re: No spark
Turns out one I hadn't plugged the power wire to the cap, the insulated connector was on the side of the lug! Got it stated but I cant get it timed, I had it at tdc, rotor pointing to number one, timing mark on zero, this is an HEI by the way. checked my firing order and it's good. It just won't time and run really smooth. I took off the vac line on dist and plugged it. Anyone have any suggestions?
11-02-2014, 08:31 PM | #9 |
Re: No spark
Off a tooth/teeth? Valves too tight?
11-03-2014, 02:58 AM | #10 | |
Re: No spark
11-02-2014, 11:39 PM | #11 |
Re: No spark
I was going to say, it's a new engine the OP didn't put it together. Go through the process again of tdc etc... ensure all plug wires are seated, grab a chilton
project: "my happy mess" Last edited by litew8; 11-03-2014 at 12:02 AM. |
11-03-2014, 07:31 AM | #12 |
Re: No spark
Check for vacuum leaks also. if its bad enough it will have the same simptoms you describe.
11-03-2014, 11:42 AM | #13 |
Re: No spark
Going to check that in just a few minutes. Thanks
11-03-2014, 11:03 PM | #14 |
Re: No spark
I'm still having issues getting this new 350 to run right, I haven't ran the engine more than a total of five minutes while I try different things but I'm starting to wonder if I'm going to damage something since the engine isn't broken in. It's not backfiring or running super rough but I have no clue if I could potentially mess something up! Am I worrying for nothing?
11-04-2014, 03:11 AM | #15 | |
Re: No spark
11-04-2014, 07:49 AM | #16 |
Re: No spark
If you can keep it running, and have oil pressure, not overheating, the most important thing right now is to get that cam and lifters broken in. keep it running around 2000 -2500 rpm for 20 or so minutes watching over engine, maybe turning the dizzy alittle to smooth things out till they break in. then worry about the other problems...
