Old 11-05-2014, 01:53 PM   #1
blown240
blown240's Avatar
Help Me Make A Couple Decisions
I am going to be pulling the motor from my 61 Panel to replace it with a newer/less worn out motor.
I am thinking that it will be easier to update the brakes while the motor is out. I am leaving it 4 wheel drum for now, but am upgrading to power brakes and a dual master cylinder. I have most of the parts to do a hydroboost, but would need to buy a new hydro unit.
My budget is VERY limited.
1. Vacuum booster or Hydroboost? Is hydro that much better with 4 wheel drums? I have the pump and a steering box, but this complicates the install I'm sure. I can get a vacuum booster for about half the price of the hydroboost.
2. Is it just as easy to run the new dual circuit brake lines with the motor in? If so, I may just get the motor in and worry about the brakes afterwards.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 11-05-2014, 01:59 PM   #2
siggyfreud
siggyfreud's Avatar
Re: Help Me Make A Couple Decisions
Not sure a hydroboost would benefit you much with drums, unless you're running a more vacuum setup and don't want to use a vacuum reservoir.
siggyfreud is offline   Reply With Quote
Old 11-05-2014, 02:01 PM   #3
blown240
blown240's Avatar
I don't mind running vacuum brakes. The motor I'm installing is a basic early 80s crate motor, so it should make plenty vacuum.
I can get a dual diaphragm booster for $50 new. A hydroboost is about $140. That extra $100 is a lot of money right now.
Old 11-05-2014, 02:03 PM   #4
Clyde65
Clyde65's Avatar
sounds like you already made your decision!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-05-2014, 02:06 PM   #5
blown240
blown240's Avatar
If hydroboost is a lot better then I will spend the money. If its just marginally better, or not as good as a dual 8" booster, than I will go vacuum.
This is going to be my daily driver, and while money it tight, I want to do it right.
Old 11-05-2014, 08:59 PM   #6
earl84
I am going to do hydroboost, but mine is a disc/drum. In my research on dong this, I read somewhere that hydroboost shouldn't be used for drum/drum, because it caused drums to crack and break. I AM NOT a hydroboost expert, or anywhere close to it, but wanted to pass this on, so hopefully you can look into it, and avert a potential disaster if this is in fact accurate. I hate giving an incomplete answer or reference, but I just can't recall where I read this. There are several places that are experts, maybe call one of them. Hydratech comes to mind.(Not an endorsement or advertisement.)
earl84 is offline   Reply With Quote
Old 11-05-2014, 11:58 PM   #7
Bears63
...just another truck junkie..
Bears63's Avatar
The big questions are, 1) How heavy is your panel and 2) Are you planning a big cam? The reason I ask is that hydroboost is great on 1 tons and up, look at my sig and you will see how I know. Second, big cam engines don't produce the vacuum for the brakes and the hydroboost will help there. However, if you are running less than a 1 ton with a stock engine, then go with the dual diaphragm booster. My $.02 anyway.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 11-06-2014, 02:04 AM   #8
blown240
blown240's Avatar
Thanks for the reply Mike!
My panel is just a C10. But the hydroboost I have is from a C30. The motor is a generic 78-85 Goodrich crate motor. The only thing I did to it was take off all the smog junk, and put some full length headers on it.
Sounds like vac boost will be just fine and maybe a bit safer.
Old 11-06-2014, 07:59 AM   #9
PGSigns
PGSigns's Avatar
Vacuum booster is just fine. I ran my 66 with the Captnfab bracket and the booster from a donor truck and the buick master cylinder. If you look through his for sale thread for the brackets there are lots of options for donor parts. The 4 wheel drum brakes did just fine.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-06-2014, 12:29 PM   #10
blown240
blown240's Avatar
Thanks again for the replies!
I have one of the Captain Fab brackets. It was literally the first thing I bought for this truck. I can get a new booster for $50.
'70 Buick Estate wagon is the master I want correct?
Old 11-07-2014, 12:25 AM   #11
Captainfab
60-66 Nut
Yes that is the master you want if you are going to use a booster with the short intermediate pushrod
Old 11-07-2014, 03:05 PM   #12
blown240
blown240's Avatar
Thanks Captain!
