11-06-2014, 08:53 PM | #1 |
What size is the "e" clip on the rear brake shoes?
I don't know the proper terms for some of this, but...what size is the "e" clip that holds the parking brake lever to the rear brake shoes? I have a '69 C-10 ½-ton. And I'm talking about the retaining clip that keeps the stud from the parking brake lever from pulling out of the hole in the rear-most brake shoe. Clear as mud?
11-07-2014, 09:36 AM | #2 |
Java Mechanic
Re: What size is the "e" clip on the rear brake shoes?
Anyone know this one?
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
11-07-2014, 04:34 PM | #3 |
Never Ending Projects
I am trying to recall from memory. I don't think that clip is a real e-clip but one that you bend the end close once you slide it on. I think I recall them coming in a brake hardware kit. Typically I can use a wide blade screwdriver to bend it back open, to remove and once I replaced the shoe, I would slide it back on and bend it close with a set of pliers.
Looked up on NAPA online and it looks like the hardware kit uses a e-clip as a replacement. http://www.napaonline.com/Catalog/Ca...202_0094753409
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
11-07-2014, 06:03 PM | #4 |
Not sure if this will help or if this is the one your talking about.. this is the only e-clip that was in my spring package. truck is a 72. size is .223 on the open end, so maybe the stud groove is .250..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
11-07-2014, 06:43 PM | #5 |
Thanks very much, guys!
