Old 11-07-2014, 04:08 PM   #1
61K10
61K10's Avatar
sealer on shims?
what type of sealer on the shims? these are off a 221 t/f case. they were leaking and the main rear shaft was a little loose. had 4 .010 shims and the cover has a small grove in it at bearing contact. I have another good cover to use.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-08-2014, 11:54 AM   #2
dieseldude4bt
Re: sealer on shims?
I sued High Tack gasket sealant #765-1221, but wonder if a copper coat gasket compound would be better?
I would also like to here from others what they use.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 11-08-2014, 12:40 PM   #3
60sIron
60sIron's Avatar
Boy it's probably been 20 years since I rebuilt mine. If I recall I didn't use anything as the shims are used to set the end play on the shaft. Correct? It wept oil and I got tired of it so I cleaned the t case and cap and put a bead of gasket sealer round the outside and wiped off the excess. Used black and it was unnoticeable and worked. Keep us posted.
Greg
60sIron is offline   Reply With Quote
Old 11-22-2014, 06:00 PM   #4
maxwoof
I used something called Hylomar Blue on mine. Seems to work well. Otherwise, I would use the black Permatex form a gasket.
maxwoof is offline   Reply With Quote
Old 11-23-2014, 08:19 AM   #5
evan396
Permatex #2 non hardening sealer should work fine. This is what we used on ours. We were wondering what you used for new seals. Evan
evan396 is offline   Reply With Quote
Old 11-23-2014, 01:15 PM   #6
61K10
61K10's Avatar
I used Indian head stuff on mine. the seals are avl from most auto part stores. rockauto lists them.
1961 chevy K10
Old 11-23-2014, 03:45 PM   #7
argonaut
argonaut's Avatar
I guess the copper doesn't work because that is what I tried to use and obviously that leaked.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 11-23-2014, 04:15 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Couple years ago I discovered Permatex® Gear Oil RTV Gasket Maker. As its name suggests, it's made specifically for use with gear oil. Good stuff. Not just to make gaskets, you can spread it thinly to seal & prevent leaks.
http://www.permatex.com/products-2/p...t-maker-detail
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-24-2014, 12:53 PM   #9
61K10
61K10's Avatar
Jason--it really didn't leak just weeped, maybe a drop or two after running. I almost used the copper as i had some on the shelf. from what i have read these 221's don't seal real well anyway. my old one had under coating on most of it and dirt only leaked at the seals.
1961 chevy K10
Old 11-24-2014, 02:16 PM   #10
Redcap
If a T221 isn't leaking, it is out of oil.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 11-24-2014, 02:27 PM   #11
argonaut
argonaut's Avatar
I do get the impression that oil weeping was, in general, kind of expected or acceptable on motors and transmissions and transfer cases back in the day. But I dont really know since I wasn't alive back then
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 11-24-2014, 04:18 PM   #12
Redcap
Some, not all. Detroit diesels are widely known as "Green Leakers".
