Newb at the 5.3L swap game...
That is what I have thought of right now for my 69'C-10 shortbed. This is just for the fueling and getting it running. I will post the installation stuff in another thread. I know there is and FAQ, and hours or threads to read, but I was just confusing myself. So, I took it back to basics. Patience is appreciated. What do you think?
-67-71 Suburban fuel tank -Airtex 01' Suburban fuel pump Part #E3501M (Max PSI=90-110 at pump w/50-60 GPH) -Russell Performance adapter fitting: http://www.summitracing.com/search?k...20641300&dds=1 -Pedal assembly (unless I go to cable) -TAP? -150tunes.com (or other recommended tuner) for tuning and adaptation of the harness Thanks! Mark
Retired Air Force/Disabled Vet 1969 Chevy C-10, On the way to greatness! |
Re: Newb at the 5.3L swap game...
The fuel pump is a stock replacement for an 01' Suburban 6.0L. I am getting the motor, accessories, 4L60, complete/uncut harness, and PCM from the same truck.
Mark
O.K., maybe I asked that wrong. Can anybody tell me if I missed or overlooked something? My plan is to mount the in tank pump in the suburban tank like I have read somewhere. I have read that there is debate over in tank or in line pumps, so I figured a stock pump would be best. If there are other affordable options, please let me know.
Mark
meowMEOWmeowMEOW
I'm not entirely sure what info your looking for but;
I have no idea what TAP is, do you mean TAC (For the drive-by-wire system)? If the donor truck was DBW, and the engine/ecm and associated wiring is all from the same truck, then all you need to do is source the TAC and pedal from the same truck. As for the tune, try to get it tuned "in person". Email tunes are fine in many cases, but there is always room for improvement in power and driveability with a physical tune. Things like shift points, firmness, TCC settings are much easier to communicate to someone in person vs mailing your ECM back and forth.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#5 | |
Thanks for your help! Mark
With that tank you will have to modify the bed from what I have read. My 04 engine does have a 2 line setup on the engine, pressue and return. I bought a 90 jeep wrangler tank for my truck but I'm going with a inline pump. It is supposed to fit reall good. It's just a 15gal tank though. I have bungs to weld in the tank for a sump feed and a 70 surburban sending unit for the fuel guage. I wouldn't recommend buying stuff until you are sure of your engines fuel setup as there are different options depending on what you have. Ask around you may find a "speed shop" that may be close to you and help with you ECM tunning. Hope this helps some.
![]() Join Date: Aug 2004
go with a Boyds tank from the vendor section. You can get one that will slide right in place behind the rear end and can also have the fuel pump already installed, options are available too.
http://67-72chevytrucks.com/vboard/s...362307&page=37
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
LT1swap.com will reprogram your PCM for $75 including return shipping.
Great info! Thanks guys!
Mark
![]() Join Date: Sep 2014
http://67-72chevytrucks.com/vboard/s...d.php?t=423035
This is another option for a tank, I want a FI tank that I can fill from behind the license plate and this is the perfect option and not to much work. You can get these tanks from Tanks Inc for pretty cheap and they are good quality FI tanks. Rich |
