Old 11-12-2014, 01:59 PM   #1
79mattstang
Dreaded Chevy Lean
I know this has been discussed before on this forum but I need some help figuring out why my truck sits about 1 1/4 inches higher on the passenger side rear. Where do I start measuring and investigating to try and level this thing out. I want to do an all coil 3-5 drop but am hesitant because my trucks sits so funky.
79mattstang is offline   Reply With Quote
Old 11-12-2014, 02:03 PM   #2
79mattstang
Re: Dreaded Chevy Lean
Pics
Old 11-12-2014, 02:07 PM   #3
steelhorse
steelhorse's Avatar
The first guess would be worn springs but you need to check all of your bushings also.
steelhorse is offline   Reply With Quote
Old 11-12-2014, 02:16 PM   #4
no1udknow
no1udknow's Avatar
and you know you will inevitably get a comment about your cheeseburger intake ...
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 11-12-2014, 02:19 PM   #5
no1udknow
no1udknow's Avatar
I have noticed though that it always seems to be the drivers side, is the drive wheel on the passenger side on limited slip diffs? That is the only explanation I could think of. Perhapse because there is torque applied to the right rear wheel, coupled with the rotational torque of the engine. But I have always noticed it is the right rear that is higher...strange
Built not bought!
Old 11-12-2014, 02:26 PM   #6
79mattstang
forgot to mention the PO installed 4 new stock coils and that didnt help.
Old 11-12-2014, 06:07 PM   #7
mechanicalman
On RWD cars with clockwise rotation engines, regardless limited slip or open diff, the R (passenger side) rear wheel will lose traction first due to more weight being put on the L(driver's side) rear wheel.
The driveshaft pushes against the pinion gear, ring gear, and pushes the L rear wheel against the ground. If you think in terms of what's happening on the engine cradle, the torque is pushing the cradle counter-clockwise. Then, looking down the frame rails, would it not twist the frame clockwise? It's not getting twisted from the rear, it's getting twisted from the front.
The engine cradle has nothing to get twisted out of shape, so the extension of the frame rails towards the rear get leveraged out of shape and hence the raising of the passenger side frame rail in the back.
The engine cradle may suffer from some spring compression that would account for front driver's side sag.
OK I'm throwing this out there! LOL
mechanicalman is offline   Reply With Quote
Old 11-12-2014, 04:40 PM   #8
jhwkns
Registered Cruiser
jhwkns's Avatar
Take it to a frame shop. I recommend that to anyone with one of these old trucks. There's no telling how many times it's been grossly overloaded through the years, how many curbs it's smacked, or someone played 'Dukes of Hazzard.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 11-12-2014, 06:10 PM   #9
leddzepp
Moderator
leddzepp's Avatar
This.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-12-2014, 07:03 PM   #10
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Originally Posted by leddzepp View Post
This.
X2.....
Same issue for me, found the frame was bent....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 11-12-2014, 09:10 PM   #11
TrkEnvy
Check the ball joints and bushings in the driver side a arm. My old dodge Cummins pickup had this going on and the bushings where the a arm attached to the frame were non existent.
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E
I call it Bruce Banner..
TrkEnvy is offline   Reply With Quote
Old 11-12-2014, 11:26 PM   #12
tsetsaf
My truck is stock height with full auto level air ride. For ride height measured from top of tread to bottom of fender no two sides are equal air pressure... for what it is worth.
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
Old 11-12-2014, 04:43 PM   #13
cayce_brunswick-
Make sure the springs are seated correctly. When they are installed it dosent take much to get them off a little.
cayce_brunswick- is offline   Reply With Quote
Old 11-12-2014, 04:51 PM   #14
Augi
Mine is on the original springs and sits much farther off than that. You also have to account for the roads, the center is higher than the outside (at least in Tennessee) so most vehicles lean like that after some miles.
We all share a common fear in our lives. The fear that when we pass along to our next lives that our wives sell our trucks for what we said we have in them.
71-Johnny Cash Special Cheyenne, Safety Blue
350-TH350, quadrajet
Augi is offline   Reply With Quote
Old 11-12-2014, 05:08 PM   #15
C/10 King
C/10 King's Avatar
My black truck does the same thing only on the other side, so when I drive it I hope it looks straight.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
