11-16-2014, 05:01 PM | #1 |
69 ChevyC20 brake conversion problem
I have recently converted my C20 to front disc brakes. I purchased the 8 lug conversion package from Brothers. I also replaced the master cylinder and prop valve with the ones they recommended. I bench bled the master cyl. installed everything according to their instructions, then bled all the wheel cyl. I have a strong pedal until I start the engine and the booster comes into play then the pedal goes to the floor and the brake light comes on. I called the CPP help desk and they told me to re-bench bleed the master, which I did re-installed and re-bled everything only to find the same issue. The tech dept. at CPP thought I might need a new booster which I didn't replace because it worked before I started this project. I have bleed the entire brake system no less than 4 times with the same results, anyone have any ideas?
11-16-2014, 07:23 PM | #2 | |
Re: 69 ChevyC20 brake conversion problem
my guess is, it's broken if the pedal doesn't stay hard.
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
11-16-2014, 07:41 PM | #3 |
Thanks I'll rebuild it and see if that works
11-16-2014, 08:04 PM | #4 |
and remember, only bleed by vacuum, not stomping on the pedal
Tags |
brake conversion problem |
