Old 11-16-2014, 08:31 PM   #1
scottco
scottco's Avatar
Engine venting
I have a 64 c10 that has a 350. I want to keep the classic look of no hole valve covers and oil filler in the intake with the breather cap. Can I tap the filler tube and put an inline pcv valve in line to carb??
1964 C10 SWB original
1970 SS El Camino
1964 Impala SS
http://67-72chevytrucks.com/vboard/s...d.php?t=649951
scottco is offline   Reply With Quote
Old 11-16-2014, 09:07 PM   #2
hotrod66
hotrod66's Avatar
Re: Engine venting
yes some of your mid year vetts (63-67) where done that way from the factory but the oil cap needs to be sealed, you may be able to get a oil fill tube with cap from ecklers corvette already set up this way.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 11-16-2014, 09:22 PM   #3
scottco
scottco's Avatar
Re: Engine venting
Cool, I have seen that set up before but couldn't remember where. Thanks for the info....
1970 SS El Camino
1964 Impala SS
Old 11-16-2014, 09:54 PM   #4
DPowers
One foot in front of the other
DPowers's Avatar
Re: Engine venting
might try this:
http://www.persh.org/pickup/ValveCovers.htm
DPowers is offline   Reply With Quote
Old 11-17-2014, 02:13 AM   #5
Captainfab
60-66 Nut
Re: Engine venting
When you run a PCV, you must have a way for air to enter the crankcase. Ideally it should be as far away from the PCV as possible. There are a couple of threads floating around here about PCV's and vents that have some pics.
