11-17-2014, 09:24 PM | #1 |
68 swb - lowering 6" in the front- too much?
Thanks for all the help everyone!
I am thinking about using 3" lowering spindles and I already have CPP 3" lowering springs. Will I run into any issues with a total 6" drop? |
11-17-2014, 11:16 PM | #2 |
Re: 68 swb - lowering 6" in the front- too much?
lots of info on the board, do some searching...
http://67-72chevytrucks.com/vboard/s...d.php?t=530394 http://67-72chevytrucks.com/vboard/s...d.php?t=199893 http://67-72chevytrucks.com/vboard/s...d.php?t=321067
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Thank you all so far you are angels!! Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
11-17-2014, 11:21 PM | #3 |
67-72 parts collector,…
You a-arms will be about 2" from the ground with a stock crossmember.
11-17-2014, 11:44 PM | #4 |
Probably closer than 2"...I think that's the same drop put on my truck prior to purchase. It is actually lower to the ground than our 2000 corvette! Found that fun fact out when I went to the only place in our area with an oil pit that the vette barely clears...the truck needed about an inch more of clearance. The other issue is that you'll find highway transitions can be real "fun" with the setup...I-10 between the TX state line and NOLA was quite a bit of adventure in spots...
http://67-72chevytrucks.com/vboard/s...d.php?t=545293 Current pic to follow later.
1949 Chevrolet 1/2 ton panel 1950 Chevrolet 1/2 ton pickup-ex Army base veh. 1967 Chevrolet short stepside shop truck 1972 402BB Suburban-Finally got her back! 1982 Mecham Racing Firebird #21 2009 GT1 Corvette 2000 Corvette convertible Last edited by 72BigBlockBurb; 11-17-2014 at 11:53 PM. Reason: added info |
11-18-2014, 06:45 PM | #5 | |
I'm going for 5" static front drop. Thinking 2" modular spindles and 3" drop springs....
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
11-18-2014, 07:04 PM | #6 | |
Need to learn how to read. Ha
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-18-2014 at 09:41 PM. |
11-18-2014, 09:21 PM | #7 | |
I can see how the drop spindles will move the a-arms closer to the road, but don't get the drop member improvement...
11-18-2014, 09:40 PM | #8 | |
The Dropmember DOES move the crossmember up in the frame. Level 1 moves the crossmember and a-arms up in the frame 1". Level 2 moves the crossmember and a-arms up in the frame 2". Level 3 moves the crossmember and a-arms up in the frame 3". (Extreme Dropmember version) http://pbfab.com/67-72-gm-truck
