Old 11-19-2014, 01:22 AM   #1
Chris Coufal
Pics of under hood wire harness routing
I'm mocking up my harness on my LS conversion and I'd like to see some shots of how you guys ran your harness just to ensure there isn't a better way to do it. Also after mock up, did you guys just drill a hole in the firewall and feed it through from inside out? What size hole was needed? Where did you run through? Thanks
Chris Coufal is offline   Reply With Quote
Old 11-20-2014, 09:59 PM   #2
Chris Coufal
Re: Pics of under hood wire harness routing
no one??
Old 11-21-2014, 06:12 PM   #3
lowlife4life
lowlife4life's Avatar
Here is my setup. Tucked all the wires for engine under intake. My plug is straight at the back of the intake. I built a full firewall so it will be a little different. The plugs i used are a round deutch 31 pin connector(2). i put my computer behind the pass seat with all my fuses and relays. i am using the same connector for my trans harness and it goes through the floor just behind the tranny tunnel great spot keeps the wires short and away from heat
lowlife4life is offline   Reply With Quote
Old 11-21-2014, 06:16 PM   #4
lowlife4life
the coils aren't installed but the wiring is all there for everything you just don't see temp sensor or alt or maf just tucked out of way till i need them
Old 11-22-2014, 12:40 AM   #5
ol_skool_chevy
ol_skool_chevy's Avatar
Dam Man............I have to admit. all those wires are Very Intimidating. I would love to do an LS engine but I suck at wiring.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 11-22-2014, 12:46 AM   #6
lowlife4life
Me neither before this truck I only wired my air ride. It isn't as hard as it looks and www.lt1swap.com is a saviour
