Old 11-23-2014, 12:30 AM   #1
muckyp
muckyp's Avatar
Steering Column and Steering Wheel Problem
Can someone help me figure this column out?
While working on my cluster lights I took the steering wheel off and lowered the column. Now I am attempting to put the steering wheel back on but nothing seems to be lining up properly. When I bolt the steering wheel on (it is a grant steering wheel), the cover between the wheel and column rubs the column when turning. Also, the gear indicator is not lining up.
Not sure if this is the problem, but behind the part where the turn signal mechanism is, there are a couple of cut outs, that look as if they are supposed to align with some tabs on the column. (pics) Do the cut outs go over the tabs?
I have been messing with this for a couple of hours now and searched here with no luck.
This all worked perfectly before I took it apart.
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 11-23-2014, 02:45 PM   #2
muckyp
muckyp's Avatar
Re: Steering Column and Steering Wheel Problem
Anyone?
70 SWB 454/TH400
Old 11-24-2014, 10:42 AM   #3
muckyp
muckyp's Avatar
Maybe these pics will help diagnose my problem. Am i missing a part or something?
70 SWB 454/TH400
Old 11-24-2014, 06:56 PM   #4
muckyp
muckyp's Avatar
For those that care, I figured it out. I attached the turn signal switch before putting the switch housing back where it went. Apparently that was preventing the switch cover from seating properly.
70 SWB 454/TH400
Old 09-14-2021, 03:41 PM   #5
fun in dirt
fun in dirt's Avatar
Digging up an old post, but I'm glad you posted your findings & solution, think this might be my problem too... ain't the search box great!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
