11-27-2014, 01:06 AM | #1 |
DBW Gas Pedal Adpater bracket for truck/suv pedal
DBW mounting bracket for 03-07 Truck/SUV Pedal $120 Shipped via USPS (**adjusted 10/4/2022) Paypal: robhartley@aol.com, enter "TPB" in message block. *** All purchases now include: USPS shipping in CONUS, paypal fees and all the necessary hardware to install the pedal bracket. *** After receiving many of requests for pedal bracket that will work with the 03-07 truck pedal, I fabricated this pedal bracket. This is a bolt in bracket that uses the 03-07 truck/SUV DBW pedal (may fit others) for the 67-72 LS conversions. Let me know if you have any questions or suggestions. ***** GEN IV flat brackets for the 05+ Corvette Pedal can be found here: http://67-72chevytrucks.com/vboard/s...d.php?t=631165 ***** **** PEDAL MOUNT INSTALL INSTRUCTIONS **** 1. Start by bolting your truck/SUV DBW pedal assembly to the mount bracket using the provided 3/4" 1/4-20 bolt. Do not tighten. 2. Next, loosely bolt the mount bracket to the firewall using the three nutserts in the firewall where the original pedal was mounted. You can do this by aligning the three pre-drilled holes on the right side of the mount bracket. Use three 3/4" 1/4-20 bolts to attach to the firewall that were included in your kit. 3. Next, align the left edge of the mount bracket with the raised vertical firewall brace. There are two pre-drilled holes on the top and bottom on the left edge that will be used as a guide to install the provided self-tapping bolts. 4. After you attach the left side of the mount bracket to the raised brace, you can tighten the three bolts on the right side of the bracket using a 7/16 socket. 5. When the pedal bracket is securely attached, you can adjust the pedal position as desired by moving the top of the DWB pedal assembly left or right. If necessary, there is also about 1/2" up or down adjustment from the slotted hole in the bottom of the DBW pedal assembly. 6. After you have the pedal in the position that you like, use a 7/16 socket to tighten the bottom bolt holding the DBW pedal assembly. 7. Next, you should actuate the pedal up and down to check for any interference in the movement. There shouldn't be any, but all the trucks are a little different so be sure to check. If there is any interference, loosen the bolt and adjust as necessary. 8. Once the DBW pedal assembly is adjusted, make sure the bottom bolt is tight and remove the mounting bracket and DBW pedal assembly from the firewall as one piece. This will hold the pedal in your desired position and allow you to drill the top hole to finish mounting the pedal assembly. 9. Next, mark the top pedal assembly hole using the DBW pedal assembly as a guide. Remove pedal assembly and then drill a 1/4" hole where previously marked. Re-install the pedal assembly with the provided 1/4" bolt and nut and tighten. This nut should be tacked in place, just like the one on the bottom, so that the DBW pedal assembly can be removed by itself without removing the entire pedal mount bracket. NOTE: If you don't have a welder, you can just tighten the top bolt and leave the DBW pedal on the bracket for reassembly. If you have any questions or suggestion about the installation, please let me know. Thanks for your purchase!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-04-2022 at 10:54 AM. Reason: - |
12-03-2014, 11:24 AM | #2 |
Re: Gas Pedal Adpater bracket for truck/suv pedal
bump
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-21-2015, 04:21 PM | #3 |
Hello was wondering if these are still available doing a 5.3 swap out of a 05 in a 72 blazer
11-21-2015, 07:32 PM | #4 | |
01-26-2017, 10:22 PM | #5 |
01-26-2017, 10:24 PM | #6 |
01-27-2017, 07:14 AM | #7 |
Re: DBW Gas Pedal Adpater bracket for truck/suv pedal
Yes I do! Price and PayPal info is in post #1.
02-01-2017, 10:03 AM | #8 |
$100 Shipped via USPS Paypal: robhartley@aol.com, enter "TPB" in message block.
02-03-2017, 07:44 PM | #9 |
Here's a bump for a solid little part. I had to notch mine to clearance for the back-half wiring plug but fits great. (I painted mine too)
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
12-05-2014, 10:09 AM | #10 |
3 brackets sold. 9 left.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-09-2014 at 10:53 AM. |
12-09-2014, 10:40 AM | #11 |
5 brackets sold. 7 left.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-09-2014 at 10:52 AM. |
12-12-2014, 09:50 AM | #12 |
6 brackets sold, 6 left.
12-12-2014, 11:55 AM | #13 |
**** INSTALL INSTRUCTIONS ****
Pedal mount instructions: 1. Start by bolting your truck/SUV DBW pedal assembly to the mount bracket using the provided 3/4" 1/4-20 bolt. Do not tighten. 2. Next, loosely bolt the mount bracket to the firewall using the three nutserts in the firewall where the original pedal was mounted. You can do this by aligning the three pre-drilled holes on the right side of the mount bracket. Use three 3/4" 1/4-20 bolts to attach to the firewall that were included in your kit. 3. Next, align the left edge of the mount bracket with the raised vertical firewall brace. There are two pre-drilled holes on the top and bottom on the left edge that will be used as a guide to install the provided self-tapping bolts. 4. After you attach the left side of the mount bracket to the raised brace, you can tighten the three bolts on the right side of the bracket using a 7/16 socket. 5. When the pedal bracket is securely attached, you can adjust the pedal position as desired by moving the top of the DWB pedal assembly left or right. If necessary, there is also about 1/2" up or down adjustment from the slotted hole in the bottom of the DBW pedal assembly. 6. After you have the pedal in the position that you like, use a 7/16 socket to tighten the bottom bolt holding the DBW pedal assembly. 7. Next, you should actuate the pedal up and down to check for any interference in the movement. There shouldn't be any, but all the trucks are a little different so be sure to check. If there is any interference, loosen the bolt and adjust as necessary. 8. Once the DBW pedal assembly is adjusted, make sure the bottom bolt is tight and remove the mounting bracket and DBW pedal assembly from the firewall as one piece. This will hold the pedal in your desired position and allow you to drill the top hole to finish mounting the pedal assembly. 9. Next, mark the top pedal assembly hole using the DBW pedal assembly as a guide. Remove pedal assembly and then drill a 1/4" hole where previously marked. Re-install the pedal assembly with the provided 1/4" bolt and nut and tighten. This nut should be tacked in place, just like the one on the bottom, so that the DBW pedal assembly can be removed by itself without removing the entire pedal mount bracket. NOTE: If you don't have a welder, you can just tighten the top bolt and leave the DBW pedal on the bracket for reassembly. If you have any questions or suggestion about the installation, please let me know. Thanks for your purchase!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-10-2015 at 04:08 PM. |
12-12-2014, 11:29 PM | #14 |
I want one
205harleyman 1972 K5 Blazer 2002 5.3 ltr engine and transmission Vintage Air 1999 tan leather bucket seats and console w/1999 back seat 20inch Torque Thrust Wheels Corvette Madrid Red with Tan Top Hope to be driving soon!!! |
12-13-2014, 10:05 AM | #15 |
Sweet! PayPal information is in the first post of the thread. Let me know so I can ship it today.
12-14-2014, 02:49 PM | #16 |
Shipped. THANKS!
Do u still want one?
12-13-2014, 03:21 PM | #17 |
I want one Rob!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
12-20-2014, 07:53 PM | #18 |
Sorry, I forgot about it, but just sent paypal
12-23-2014, 01:04 PM | #19 |
No worries! It shipped yesterday. Thanks again.
R
01-04-2015, 12:33 AM | #20 |
Bump for a great seller. The bracket installed easily and is a great time saver.
01-06-2015, 12:45 PM | #21 |
hi I was wondering if you have any brackets left?
01-06-2015, 01:09 PM | #22 | |
Yes I do! The price is 100.00, Paypal is robhartley@aol.com. Thanks!
Thanks Jonathan!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-27-2016 at 09:07 PM. |
01-06-2015, 01:44 PM | #23 |
Just got your PM, I'll take one well!
01-06-2015, 01:50 PM | #24 |
01-06-2015, 02:06 PM | #25 |
