11-29-2014, 10:06 AM | #1 |
big sway bar with end links
Anyone know of a junkyard Sway bar that has end links not the 67-72 style that mounts directly to the a-arm . Looking for something that I can grab at a pull yard. Perhaps something in the 1 1/4 range.
11-29-2014, 12:06 PM | #2 |
Re: big sway bar with end links
Not sure of a wrecking yard jewel but I know of a new unit that's great 'bang for the buck'.
Bell Tech offers a 1 3/8" beast that uses end-links vs the the OE style bushings. I got one from Summit for less than $200. Comes to you powder-coated grey w/poly bushings.
11-29-2014, 12:24 PM | #3 |
That's what I have. Very nice piece.... By the time you find a bar that may fit, buy it, replace all the bushings and then figure out how to mount it you'll be into it for $100 at least(assuming you find the right bar the first time). I know about the "built not bought" thing, but sometimes its just better to open up the wallet. On the other hand, I had thought about cutting a stocker big bar and fabbing tabs for endlinks. It may have worked, but I'd have always wondered if the next hard corner was going to be the one that broke it..... The belltech piece is really nice......
11-29-2014, 12:49 PM | #4 |
I've also thought about welding tabs on a bar that was "close" but I'm sure that weld would always be in the back of my mind
11-29-2014, 12:50 PM | #5 |
The beltech one . Is it a universal pice or is it vehicle specific ?
11-29-2014, 02:43 PM | #6 |
Vehicle specific P/N 5404 I believe. I saw it for $175 thru a google search
11-29-2014, 07:34 PM | #7 |
Sounds right. Summit had free delivery too since it was over $99.
11-29-2014, 09:13 PM | #8 |
If you could install a rack and pinion, a sway bar from 99-06 Chevy/GMC trucks will work. If you still have a stock steering box, the bar interferes with the idler and pitman arms.
11-29-2014, 09:23 PM | #9 |
Not to hijack the thread but what would be a good matching bar for the rear for the Belltech bar?
Answering my own question I guess, the matching rear bar from Belltech is a 1 1/8" rear bar number 5508. But the application is for an 85 C10 which is also a leaf spring truck. Not sure if the same size would apply to a rear coil truck or not ...
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 Last edited by 66 C10 383; 11-29-2014 at 09:40 PM. |
11-30-2014, 01:33 PM | #10 | |
11-30-2014, 01:43 PM | #11 | |
11-30-2014, 01:12 AM | #12 |
honestly..just buy you a new one.. the time and money u spend trying to make one work is not worth it.. now having said that ive found 2 OE sway bars in the local wrecking yards...i just got lucky..
1966 C10 Mary 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
11-30-2014, 08:53 AM | #13 |
Do you know what you huck yard bars came off of ?
11-30-2014, 01:35 PM | #14 |
