11-29-2014, 12:02 PM | #1 |
Reverse problems-please help
Alright, straight to it, my truck wont go in reverse. when I shift it to R, it creeps back a little, but when I step on the gas it just revs but still creeps back at the same speed. I checked the fluid and it looks like it needs more which ill get tomorrow, but could it be anything else? it goes forwards fine in drive and low. whats wrong?
Grandpa's '87 Sierra R1500. |
11-29-2014, 12:15 PM | #2 |
Re: Reverse problems-please help
Fluid needs to be full. Then, if it still doesn't move in reverse but moves forward in the forward gears, it's time for a rebuild.
11-29-2014, 01:53 PM | #3 |
okay ill try that and see if it helps
11-29-2014, 04:56 PM | #4 |
Not sure what trans you have but I had an 84 blazer with a 700r4 that reverse went out in followed shortly by first. Never fixed it just sold it. Not sure if the 700 has a reverse band/sun shell? that can be adjusted externally by dropping the pan. Its a pain in the ass I know, just lived with a suburban with no reverse for almost 3 months but it had a 4l80e.
11-29-2014, 06:16 PM | #5 |
Active Member
Not sure what trans you got but my buddys 78/350/350 his did this and a month later first went out and now no foward or reversae..so ya time for a rebuild.
