![]() Join Date: Oct 2013
1960 With Fat Man front end on shockwaves opinion needed
Couple questions for the bagged crowd out there. I have a 1960 fleet side that I just put a Fat Man Fab hub to hub kit in with ridetech shockwaves. I have the ridetech bag set up in the rear. My question is, how many out here are running 20's up front with no mod to the inner fender and how far can you get it down on a 20 with non modded inner fenders. I'm not looking to lay frame, just want a nice ride and stance.
Any help out there??? |
Re: 1960 With Fat Man front end on shockwaves opinion needed
Not mine but here ya go.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Can't seem to get link I want. Text from Ride Tech says 21" from ground to center of fenders on a 24" tire
http://www.cardomain.com/ridepost/83...-pick-up/#next
#5 | |
Stock arms aired out no notch. Problem is stock arms push axle up and forward into bed. That's why I went Porterbuilt rear arms. I still really not into notch. 11 inch to rear frame aired out. See my build from budget to overkill. It has taken some time to get it this far never mind $$$. I work too hard not to do this one right.
#7 | |
295/45/18 ...28.4" Nitto 555s or early 275/60/15.
At 225/70/15 temp fronts, plan is 245/45/18. Match salt flats at 18x8.5. Vs rear 18x9.5
